    Duex5 error when powering on
    • resh
      resh last edited by
      I've got a duet wifi2 and duex5 and when just the ribbon cable and vin is supplied I'm getting numerous errors. It's just when I turn it on and nothing is hot. The errors stop appearing after a couple minutes.
      Error: over temperature shutdown reported by drivers 5 6 7 8 9
      Error: short to ground reported by drivers 5 9
      Thanks for the help
        Can you please post your config.g and the results of M122 and M98 P"config.g" ?
        What do you have connected where?
        How do you have your Duex power and ground connected?
        It should be as described here: https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
        resh 1 Reply Last reply Reply Quote 0
        • resh
          resh @Phaedrux last edited by
          @phaedrux The duex5 is connected exactly like the picture you linked. The only thing connected to the duex5 is the power/gnd and the ribbon cable. I'm unfamiliar that last M98 line you're requesting.
          Thanks for the help. I see others posting their config files in a better format than copy/paste. If it's easier that way please let me know how to do that.
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3RC3 (2021-05-26 13:47:14) running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DGM-956GU-DGMSN-6JTD4-3SD6Q-1VRMH
          Used output buffers: 5 of 24 (19 max)
          Static ram: 23876
          Dynamic ram: 75736 of which 0 recycled
          Never used RAM 14804, free system stack 184 words
          Tasks: NETWORK(ready,12.1%,252) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0%,24) MAIN(running,85.2%,441) IDLE(ready,2.6%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:00:28 ago, cause: power up
          Last software reset at 2021-03-20 20:52, reason: User, GCodes spinning, available RAM 14960, slot 2
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 27.7, current 31.1, max 31.4
          Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0, ok, SG min/max not available
          Driver 6: position 0, ok, SG min/max not available
          Driver 7: position 0, ok, SG min/max not available
          Driver 8: position 0, ok, SG min/max not available
          Driver 9: position 0, ok, SG min/max not available
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-06-08 17:15:11
          Cache data hit count 1005073547
          Slowest loop: 4.89ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.2ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === DueX ===
          Read count 1, 2.12 reads/min
          === Network ===
          Slowest loop: 15.60ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address 84:0d:8e:b2:7c:16
            WiFi Vcc 3.36, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 24960
            WiFi IP address 192.168.1.233
            WiFi signal strength -32dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Feb 26 2021 10:46:02 GMT-0500 (Eastern Standard Time)
          M550 P"My Printer" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S0 ; physical drive 0 goes forwards s1 is forward s0 backwards
          M569 P2 S0 ; physical drive 2 goes forwards
          M569 P3 S1
          M569 P4 S0 ; physical drive 3 goes forwards
          M584 X0 Y1 Z2:4 E3 ; set drive mapping
          M671 X-20:290 Y0:0 S5 ;leadscrews at left (connected to Z) and right (connected to E1) of X axis
          M208 X10:300 Y0:180 ;X carriage moves from -5 to 270, Y bed goes from 0 to 130
          M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X310 Y310 Z180 S0 ; set axis maxima
          M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin !xstop
          M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin !ystop
          M574 Z2 S2 ; configure Z-probe endstop for high end on Z
          ; Z-Probe ; create servo pin 0 for BLTouch
          M950 S0 C"duex.pwm1"
          G31 P500 X27 Y0 Z1.28 ; set Z probe trigger value, offset and trigger height
          M557 X15:215 Y15:195 S20 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 R0.135 C738.7 D1.34 S1.00 V23.5 ; enable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin e0temp
          M307 H1 B0 R2.039 C177.8 D6.23 S1.00 V24.0 ; disable bang-bang mode for heater and set PWM limit
          M143 H1 S285 ; set temperature limit for heater 1 to 280C
          M575 P1 S1 B57600 ;enable support for PanelDue
          T0 ; Select first tool
            Do you see any damage on the Duex5 drivers? Can you post a photo?
            When and where was it purchased?
            @resh said in Duex5 error when powering on:
            M98 P"config.g" runs config.g as a macro and any syntax errors that may not have been caught during bootup will show in the console.
            To post your text as code you encapsulate it with ``` marks above and below the text block.
            • resh
              @phaedrux There's no damage to the chips or surrounding area.
              Got it used off ebay. I'll send it back.
              I appreciate the help.
