    Duet 2 Wi-Fi/ethernet conversion
    cnc mode ethernet wifi module duet 2 wifi firmware
    • gzundefined
      gz
      Hello everyone!
      I'm going to replace the wifi module on my duet 2 with an ethernet module I'm using it on a CNC running the cnc version of DWC, since the board is in an industrial electric box that's made from steel I always have to keep it open and facing up to get a decent enough connection for it to be usable and also interference from everything else in the box must not help. I don't have any trouble with soldering as i've done way harder before, but I'm not sure what to do after that, do I have to flash another firmware that's for the ethernet on my duet or do I just change the wifi connection commands and is there anything else I need to change or flash? Thanks a bunch!
        Going from wifi to ethernet you won't have to do any firmware flashing. You may need to change the network setup depending on if you want to use DHCP reservation at the router or define a static ip in the config.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M552_Set_IP_address_enable_disable_network_interface
        gzundefined 1 Reply Last reply Reply Quote 1
        • Vetiundefined
          Veti
          here is a log of someone doing it. it might help anyway
          https://forum.duet3d.com/topic/2890/converting-a-duet-wifi-to-a-duet-ethernet
          • gzundefined
            gz @Phaedrux
            @phaedrux thank you very much for your reply ! i thought as much but wanted to make sure there is no firmware changes involved ! thanks !
            • gzundefined
              gz @Veti
              @veti thanks a lot ! i saw another post from someone who did it but i didn't see this one thanks !
              Michael Hathawayundefined 1 Reply Last reply Reply Quote 0
              • Michael Hathawayundefined
                Michael Hathaway @gz
                I think the Ethernet boards are superior, because they are not constantly disconnecting and if you have an access point on the network, it can be wireless as well.
                Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
                www.MatterHackers.com - https://discord.gg/Ked7GREqux
