Error: Probe was not triggered during probing move
@milan-baca does it do that at the same probe point each time, or at different points?
In this line:
M558 P9 C"io7.in" H15 F150 T6000 R0.2 A5
you could try increasing R0.2 to R0.3. If that doesn't fix it then I suspect that the pin of the BLTouch may be sticky. Is it a genuine BLTouch, or a clone?
@dc42 triangle lab (not genuine) - but this one I am using on my other printer (I took it from there) with duet2 wifi for years and it works well there
@milan-baca you could also try reducing the maximum Z speed in M203, in case the Z axis can't keep up with the commanded speed when the probe is raised.
@dc42 thank you very much again
R0.3 was the trick
