    Firmware 2.05 ->3.3RC3 does not update
    RepRapFirmware on other controllers
    • AS-3D Druckundefined
      AS-3D Druck
      Hey Guys,
      i just tryed to update my Duet Wifi to the latest Firmware but it's a "few" Years ago since the last update.
      I uploaded the latest WifiServer 1.26 and it updated just fine.
      After that i uploaded "Duet2CombinedFirmware.bin" like the Wifiserver to System->Upload System Files and it restarts and does everything but it show still this:
      Electronics
       Diagnostics
      Board: Duet WiFi 1.0 or 1.01 (duetwifi10)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05 (2019-12-13b1)
      Duet WiFi Server Version: 1.26
      Note: You can install updates on the System page.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.0 or 1.01
      Why dosen't want to update?
      Downloaded from:
      https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3RC3
      Best regards
      AS-3D Druck / Andre
        Phaedrux Moderator @AS-3D Druck
        @as-3d-druck said in Firmware 2.05 ->3.3RC3 does not update:
        You must first update to 3.0.
        If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
        That will get your firmware and DWC up to date.
        You can see the change logs here:
        https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
        For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
        https://configtool.reprapfirmware.org/Start
        Backup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
        These documents will come in handy during the conversion.
        https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
        https://duet3d.dozuki.com/Wiki/Gcode
        AS-3D Druckundefined 1 Reply Last reply Reply Quote 1
          AS-3D Druck @Phaedrux
          @phaedrux
          Okay i updatet the Firmware to 3.0 and did the same for 3.2.2 but it says for 10 min ~
          (I turned it off and back on and it was updated)
          Please wait while updates are being installed...
          No LED is blinking on the Board.
          Shut i turn it off and back on?
          I updated my config with that Tool and i hope it is now fine. (will be tested after the Update)
          I saved everything from the System just in Case. 😉
          thx
          Best regards
          AS-3D Druck / Andre
            If you're seeing this for more than a few minutes you can safely power cycle the board. When it comes back up see if the firmware was applied or not with M115.
            Did you update to 3.2.2 or 3.3RC3?
            AS-3D Druckundefined 1 Reply Last reply Reply Quote 0
              @phaedrux
              I turned it off and on again and M115 gave me the Firmware Version i installed before.
              (So 3.2.2)
              Yes, i installed 3.3RC3 right after that.
              Best regards
              AS-3D Druck / Andre
                dc42 administrators @AS-3D Druck
                @as-3d-druck we expect to release 3.3 stable very soon so you may wish to wait for that.
                  AS-3D Druck @dc42
                  @dc42 okay thx, but i installed RC3 already so it is okay for me i guess. 🙂
                  Best regards
                  AS-3D Druck / Andre
