    Infinite loop?
    Gcode meta commands
    682
    • K01571N3Nundefined
      K01571N3N
      Hi! I posted earlier about led controlling with loops. Now i got new firmware and variables are working but...
      I cant do a infinite loop because printers status is then busy all the time and i cant do anything because of "busy"...
      Does anyone have any idea how to do that?
      Heres some code
      ; Configuration file for Duet3
      ; Executed when Duet 3 is started
      M80 ; Power supplies ON
      ; General parameters
      G90			; Absolute coordinate
      M83			; Relative extrusion
      M550 P"Koistisen TC1"	; Printer's name
      M669 K1			; Printer's kinematics = CoreXY
      ; Motor drivers
      M569 P1.0 S1							; Motor 1.0 CW (X)
      M569 P1.1 S1							; Motor 1.1 CW (Y)
      M569 P0.3 S1							; Motor 1.2 CW (Z)
      M569 P0.0 S1							; Motor 0.0 CW (C)
      M569 P0.1 S0							; Motor 0.1 CCW (E0)
      M569 P0.2 S0							; Motor 0.2 CCW (E1)
      M569 P0.5 S0							; Motor 0.3 CCW (E2)
      M584 X1.0 Y1.1 Z0.3 C0.0 E0.1:0.2:0.5	; Motor axis parameters
      M350 X16 Y16 Z16 I1						; XYZ-Microstepping with integration
      M350 E16:16:16 I1						; E-Microstepping with integration
      M350 C8 I0							; C-Microstepping with integration
      ; Motor parameters
      M92 X200.00 Y200.00 Z3200.00 C100 E829.00:829.00:829.00			; Step/mm
      M566 X500.00 Y500.00 Z100.00 C300.00 E500.00:500.00:500.00		; Max allowable instantaneous speed change = Jerk (mm/min)
      M203 X17000.00 Y17000.00 Z800.00 C5000.00 E9000.00:9000.00:9000.00	; Max speed (mm/min)
      M201 X1500.00 Y1500.00 Z300.00 C500.00 E2000.00:2000.00:2000.00		; Acceleration (mm/s^2)
      M906 X1100 Y1100 Z1600 C400 E1300:1300:1300 I30				; Motor current (mA) and motor idle factor in per cent
      M84 S30			                				; Set idle timeout
      ; Axis limits
      M208 X0:365 Y0:362 Z0:509 C-120:120	; Min/Max
      M574 X1 S1 P"1.io0.in"		; X-Endstop = 1.io0.in
      M574 Y1 S1 P"1.io1.in"		; Y-Endstop = 1.io1.in
      M574 Z1 S2			; Z-Endstop = Z-Probe
      M558 P8 C"0.io8.in" H1 F120 T15000	; Z-Probe = Microswitch. Measuring depth ja speed. Input = C"1.io2.in"
      G31 P1000 X0 Y0 Z0			; Z-Probe triggervalue and offset
      M557 X0:367 Y50:310 S30			; Bed calibration
      ; Bed
      M308 S0 P"1.temp0" Y"thermistor" T100000 B4138 A"Peti"	; Heat sensor 0 = 1.temp0
      M950 H0 C"0.out0" T0					; Heater 0 = 0.out0 = Heat sensor 0
      M307 H0 B0 S1.00					; PID-control, max PWM-value
      M140 H0							; Bed = Heater 0
      M143 H0 S120						; Lämpöraja lämmitin 0 = 0-120C
      ; Tool 0
      M308 S1 P"0.temp0" Y"thermistor" T100000 B4138 A"T0"	; Heat sensor 1 = 0.temp0
      M950 H1 C"0.out1" T1					; Heater 1 = 0.out1 = Heat sensor 1
      M307 H1 B0 S1.00					; PID-control, max PWM-value
      M143 H1 S280						; Thermal limit for heater 1 = 0-280C
      ; Tool 1
      M308 S2 P"0.temp1" Y"thermistor" T100000 B4138 A"T1"	; Heat sensor 2 = 0.temp1
      M950 H2 C"0.out2" T2					; Heater 2 = 0.out2 = Heat sensor 2
      M307 H2 B0 S1.00					; PID-control, max PWM-value
      M143 H2 S280						; Thermal limit for heater 2 = 0-280C
      ; Tool 2
      M308 S3 P"0.temp2" Y"thermistor" T100000 B4138 A"T2"	; Heat sensor 3 = 0.temp2
      M950 H3 C"0.out3" T3					; Heater 3 = 0.out3 = Heat sensor 3
      M307 H3 B0 S1.00					; PID-control, max PWM-value
      M143 H3 S280						; Thermal limit for heater 3 = 0-280C
      ; Tool 0
      M950 F0 C"0.out7" Q500			; Fan 0 = 0.out7 = 500hz
      M106 P0 C"T0/Kappale" S0.0 H-1		; Fan 0 name = "Kappale". Without temperature control
      M950 F1 C"0.out4" Q500			; Fan 1 = 0.out4 = 500hz
      M106 P1 C"T0/HotEnd" S1.0 H1 T50 L1.0	; Fan 1 name = "HotEnd". Temperature control = Heat sensor 1 = 50C
      ; Tool 1
      M950 F2 C"0.out8" Q500			; Fan 2 = 0.out8 = 500hz
      M106 P2 C"T1/Kappale" S0.0 H-1		; Fan 2 name = "Kappale". Without temperature control
      M950 F3 C"0.out5" Q500 			; Fan 3 = 0.out5 = 500hz
      M106 P3 C"T1/HotEnd" S1.0 H2 T50 L1.0	; Fan 3 name = "HotEnd". Temperature control = Heat sensor 2 = 50C
      ; Tool 2
      M950 F4 C"0.out9" Q500			; Fan 4 = 0.out8 = 500hz
      M106 P4 C"T2/Kappale" S0.0 H-1		; Fan 4 name = "Kappale". Without temperature control
      M950 F5 C"0.out6" Q500 		        ; Fan 5 = 0.out5 = 500hz
      M106 P5 C"T2/HotEnd" S1.0 H3 T50 L1.0	; Fan 5 name = "HotEnd". Temperature control = Heat sensor 2 = 50C
      ; Tool 0 "BMG1"
      M563 P0 S"BMG1" D0 H1 F0	; Tool 0 parameters
      G10 P0 X0 Y0 Z0			; Tool 0 offset
      G10 P0 R0 S0			; Tool 0 valmius- ja käyttölämpötilat 0C/0C
      ;M591 D0 P7 S1 L7 C"0.io0.in"	; Tool 0 Filament sensor
      ; Tool 1 "BMG2"
      M563 P1 S"BMG2" D1 H2 F2	; Tool 1 parameters
      G10 P1 X0 Y0 Z0			; Tool 1 offset
      G10 P1 R0 S0			; Tool 1 valmius- ja käyttölämpötilat 0C/0C
      ;M591 D1 P7 S1 L7 C"0.io1.in"	; Tool 1 Filament sensor
      ; Tool 2 "BMG3"
      M563 P2 S"BMG3" D2 H3 F4	; Tool 2 parameters
      G10 P2 X0 Y0 Z0			; Tool 2 offset
      G10 P2 R0 S0			; Tool 2 valmius- ja käyttölämpötilat 0C/0C
      ;M591 D2 P7 S1 L7 C"0.io2.in"	; Tool 2 Filament sensor
      ; Tool 3 "JYRSIN"
      M563 P3 S"JYRSIN" F-1		; Tool 3 parameters
      G10 P3 X0 Y0 Z0			; Tool 3 offset
      ; Macros
      M98 P"0:/sys/VariableReset.g"	; Variable reset
      ;M98 P"0:/sys/LEDControl.g"     ; LED Control Loop start <--printer wont start because of the loop
      M98 P"0:/sys/BedOrigin.g"	; Bed zeropoint G55
      M98 P"0:/sys/ToolActive.g"	; Active tool reading
      ; Other
      M911 S23 R23.8 P"M500 M913 X0 Y0 C0 M150 S60 G91 M83 G1 Z2 E-1 F1000"	; Voltage threshold
      M501	; Load saved parameters from config-override.g
      ; Tool Offsets
      G10 P0 X4.5 Y39 Z-46.		; Tool 0 offset
      G10 P1 X4.5 Y39 Z-45.95		; Tool 1 offset
      G10 P2 X4.5 Y39 Z-45.85		; Tool 2 offset
      ; VariableReset.g
      ; Resets all variables
      ; 14.06.2021 16:16
      ; LED Variable reset
      ; Mode-----------------
      global LEDMode = "OFF"
      global LEDModeLast = "OFF"
      var LEDModeMemory = "OFF"
      ; Color----------------------
      global LEDAllColor = "White"
      global LEDBedColor = "White"
      global LEDFrameColor = "White"
      global LEDToolHeadColor = "White"
      ; Dimming--------------
      global LEDAllDim = 0
      global LEDBedDim = 0
      global LEDFrameDim = 0
      global LEDToolHeadDim = 0
      ; All---------------
      global AllRed = 0
      global AllGreen = 0
      global AllBlue = 0
      global AllCustomRed = 0
      global AllCustomGreen = 0
      global AllCustomBlue = 0
      ; Bed---------------
      global BedRed = 0
      global BedGreen = 0
      global BedBlue = 0
      global BedCustomRed = 0
      global BedCustomGreen = 0
      global BedCustomBlue = 0
      ; Frame---------------
      global FrameRed = 0
      global FrameGreen = 0
      global FrameBlue = 0
      global FrameCustomRed = 0
      global FrameCustomGreen = 0
      global FrameCustomBlue = 0
      ; ToolHead---------------
      global ToolHeadRed = 0
      global ToolHeadGreen = 0
      global ToolHeadBlue = 0
      global ToolHeadCustomRed = 0
      global ToolHeadCustomGreen = 0
      global ToolHeadCustomBlue = 0
      ; Tool Variable reset
      var CurrentToolMemory = -1
      ; Filament Variable reset
      global FilamentName = 0
      global FilamentTemperature = 0
      global FilamentRetract = 0
      ; LED-Control
      ; LED Control loop
      ; 10.06.2021
      ; Signal colors
      ; Blue = Waiting
      ; Red = Error/emergency
      ; Yellow = Warning/operator
      ; Green = Running
      ; Global variables for mode:
      ; global.LEDMode = <Mode>
      ; global.LEDModeLast = <ModeLast>; This is used automatically
      ; <Mode>		(Explanation)
      ; WorkLight		(Bed static white, Frame static white, ToolHead static white)
      ; Homing		(Bed flashing yellow, Frame static white, ToolHead flashing yellow)
      ; Printing		(Bed static green, Frame static white, ToolHead static white)
      ; ToolChange	(Bed flashing green, Frame static white, ToolHead flashing yellow)
      ; FilamentWait	(Bed flashing blue, Frame static white, ToolHead static yellow)
      ; Wait			(Bed flashing blue, Frame static white, ToolHead static white)
      ; PrintFinished	(Bed flashing green slow low dim, Frame OFF, ToolHead OFF)
      ; OFF			(Bed OFF, Frame OFF, ToolHead OFF)
      ; Warning		(Bed flashing yellow, Frame static white, ToolHead static white)
      ; Error			(Bed flashing red, Frame static red, ToolHead static White)
      ; Custom		(Give your own parameters for color and dimming, will reset every time when Mode changed)
      ; Global variables for color:
      ; global.LEDAllColor = <Color>
      ; global.LEDBedColor = <Color>
      ; global.LEDFrameColor = <Color>
      ; global.LEDToolHeadColor = <Color>
      ; <Color>: Red, Green, Blue, White, Yellow, Custom
      ; Global variables for dimming
      ; global.LEDAllDim = <Dim>
      ; global.LEDBedDim = <Dim>
      ; global.LEDFrameDim = <Dim>
      ; global.LEDToolHeadDim = <Dim>
      ; <Dim>: 0-255
      ; Global variables for custom color:
      ; global.AllCustomRed = <ColorRGB>
      ; global.AllCustomGreen = <ColorRGB>
      ; global.AllCustomBlue = <ColorRGB>
      ; global.BedCustomRed = <ColorRGB>
      ; global.BedCustomGreen = <ColorRGB>
      ; global.BedCustomBlue = <ColorRGB>
      ; global.FrameCustomRed = <ColorRGB>
      ; global.FrameCustomGreen = <ColorRGB>
      ; global.FrameCustomBlue = <ColorRGB>
      ; global.ToolHeadCustomRed = <ColorRGB>
      ; global.ToolHeadCustomGreen = <ColorRGB>
      ; global.ToolHeadCustomBlue = <ColorRGB>
      ; <ColorRGB>: Value 0-255 for each color
      ; M150 U255 R255 S18 P255 F1			; LED Bed = Yellow
      ; M150 R255 U255 B255 S29 P255 F1		; LED Frame = White
      ; M150 R255 U255 B255 S3 P255			; LED ToolHead = White
      M150 X0 Q3000000
      while 1=1								; Main control Loop
        set global.LEDMode = {global.LEDModeLast}
        ; Modes
        while global.LEDMode = "WorkLight"		; Enter loop
          M150 R255 U255 B255 S18 P255 F1		; LED Bed = White
          if global.LEDMode != "WorkLight"
            set global.LEDModeLast = "Worklight"
            break								; Exit loop
        while global.LEDMode = "Homing"			; Enter loop
          M150 R255 U255 S18 P255 F1			; LED Bed = Yellow
          M150 R255 U255 S3 P255				; LED ToolHead = Yellow
          G4 P1000							; 1000ms time delay
          M150 R255 U255 S18 P0 F1			; LED Bed = OFF
          M150 R255 U255 S3 P0				; LED ToolHead = OFF
          if global.LEDMode != "Homing"
            set global.LEDModeLast = "Homing"
            break								; Exit loop
        while global.LEDMode = "Printing"		; Enter loop
          M150 U255 S18 P255 F1				; LED Bed = Green
          if global.LEDMode != "Printing"
            set global.LEDModeLast = "Printing"
            break								; Exit loop
        while global.LEDMode = "ToolChange"	; Enter loop
          M150 U255 S18 P0 F1					; LED Bed = OFF
          if global.LEDMode != "ToolChange"
            set global.LEDModeLast = "ToolChange"
            break								; Exit loop
        while global.LEDMode = "Wait"			; Enter loop
          M150 B255 S18 P255 F1				; LED Bed = Blue
          M150 B255 S18 P0					; LED Bed = OFF
          if global.LEDMode != "Wait"
            set global.LEDModeLast = "Wait"
            break								; Exit loop
        while global.LEDMode = "PrintFinished"; Enter loop
          M150 U255 S18 P130 F1				; LED Bed = Green
          M150 R255 U255 B255 S29 P0 F1		; LED Frame = OFF
          M150 R255 U255 B255 S3 P0			; LED ToolHead = OFF
          G4 P2000							; 2000ms time delay
          M150 U255 S18 P0					; LED Bed = OFF
          if global.LEDMode != "PrintFinished"
            set global.LEDModeLast = "PrintFinished"
            break								; Exit loop
        while global.LEDMode = "OFF"			; Enter loop
          M150 R255 U255 B255 S18 P0 F1		; LED Bed = OFF
          if global.LEDMode != "OFF"
            set global.LEDModeLast = "OFF"
            break								; Exit loop
        while global.LEDMode = "Warning"		; Enter loop
          M150 R255 U255 S18 P0				; LED Bed = OFF
          if global.LEDMode != "Warning"
            set global.LEDModeLast = "Warning"
            break								; Exit loop
        while global.LEDMode = "Error"			; Enter loop
          M150 R255 S18 P255 F1				; LED Bed = Red
          M150 R255 S29 P255 F1				; LED Frame = Red
          M150 R255 S18 P0					; LED Bed = OFF
          if global.LEDMode != "Error"
            set global.LEDModeLast = "Error"
            break								; Exit loop
        ; Custom LEDs
        while global.LEDMode = "Custom"
          ; All colors--------------------
          if global.LEDAllColor = "Custom"
            set global.AllRed = {global.AllCustomRed}
            set global.AllGreen = {global.AllCustomGreen}
            set global.AllBlue = {global.AllCustomBlue}
          if global.LEDAllColor = "Red"
          set global.AllRed = 255
          set global.AllGreen = 0
          set global.AllBlue = 0
          if global.LEDAllColor = "Green"
            set global.AllRed = 0
            set global.AllGreen = 255
          if global.LEDAllColor = "Blue"
            set global.AllBlue = 255
          if global.LEDAllColor = "Yellow"
          if global.LEDAllColor = "White"
          ; Bed colors--------------------
          if global.LEDBedColor = "Custom"
            set global.BedRed = {global.BedCustomRed}
            set global.BedGreen = {global.BedCustomGreen}
            set global.BedBlue = {global.BedCustomBlue}
          if global.LEDBedColor = "Red"
            set global.BedRed = 255
            set global.BedGreen = 0
            set global.BedBlue = 0
          if global.LEDBedColor = "Green"
            set global.BedRed = 0
            set global.BedGreen = 255
          if global.LEDBedColor = "Blue"
            set global.BedBlue = 255
          if global.LEDBedColor = "Yellow"
          if global.LEDBedColor = "White"
          ; Frame colors--------------------
          if global.LEDFrameColor = "Custom"
            set global.FrameRed = {global.FrameCustomRed}
            set global.FrameGreen = {global.FrameCustomGreen}
            set global.FrameBlue = {global.FrameCustomBlue}
          if global.LEDFrameColor = "Red"
            set global.FrameRed = 255
            set global.FrameGreen = 0
            set global.FrameBlue = 0
          if global.LEDFrameColor = "Green"
            set global.FrameRed = 0
            set global.FrameGreen = 255
          if global.LEDFrameColor = "Blue"
            set global.FrameBlue = 255
          if global.LEDFrameColor = "Yellow"
          if global.LEDFrameColor = "White"
          ; ToolHead colors--------------------
          if global.LEDToolHeadColor = "Custom"
            set global.ToolHeadRed = {global.ToolHeadCustomRed}
            set global.ToolHeadGreen = {global.ToolHeadCustomGreen}
            set global.ToolHeadBlue = {global.ToolHeadCustomBlue}
          if global.LEDToolHeadColor = "Red"
            set global.ToolHeadRed = 255
            set global.ToolHeadGreen = 0
            set global.ToolHeadBlue = 0
          if global.LEDToolHeadColor = "Green"
            set global.ToolHeadRed = 0
            set global.ToolHeadGreen = 255
          if global.LEDToolHeadColor = "Blue"
            set global.ToolHeadBlue = 255
          if global.LEDToolHeadColor = "Yellow"
          if global.LEDToolHeadColor = "White"
          M150 R{global.BedRed} U{global.BedGreen} B{global.BedBlue} P{global.LEDBedDim} S18 F1					; LED Bed
          M150 R{global.FrameRed} U{global.FrameGreen} B{global.FrameBlue} P{global.LEDFrameDim} S29 F1			; LED Frame
          M150 R{global.ToolHeadRed} U{global.ToolHeadGreen} B{global.ToolHeadBlue} P{global.LEDToolHeadDim} S3	; LED ToolHead
          if global.LEDMode != "Custom"
            set global.LEDModeLast = "Custom"
            break
        dc42 administrators @K01571N3N
        @k01571n3n where did you put the LED code: in daemon.g or somewhere else?
        K01571N3Nundefined 1 Reply Last reply Reply Quote 0
          K01571N3N @dc42
          @dc42 what you mean by led code? do you mean that led control loop? and what is daemon.g?
            @k01571n3n said in Infinite loop?:
            I mean the third file that you listed in your original post in this thread.
            daemon.g is a file that you can have in your /sys folder on the SD card to execute background tasks.
              K01571N3N @dc42
              @dc42 Hi, yesterday I couldn't answer because this site said i was spamming... 😄
              tried that daemon file but it didnt work
              it was something like that
                  break								; Exit loop
                  break								; Exit loop
                  break
              i also tried to change while to if
              if global.LEDMode = "WorkLight"		; Enter loop
              if global.LEDMode = "Homing"			; Enter loop
              if global.LEDMode = "Printing"		; Enter loop
              i also tested that the daemon.g is executed by adding m291 there and it works. but the led control dont work
              jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                jay_s_uk @K01571N3N
                @k01571n3n how are you setting LEDMode to begin with? and how are you switching between the different modes?
                  K01571N3N @jay_s_uk
                  @jay_s_uk in config.g is M98 P"VariableReset.g" and all variables are resetted to something i want in that VariableReset.g. LEDMode is "OFF" and for example, in tool change macro have set global.LEDMod = "ToolChange", when printing LEDMode = "Printing" etc
                    jay_s_uk @K01571N3N
                    @k01571n3n can I suggest something like this?
                    if {global.LEDMode == "WorkLight" && global.LEDModeLast != "WorkLight"}	; Enter loop
                    if {global.LEDMode == "Homing" && global.LEDModeLast != "Homing"}			; Enter loop
                    if {global.LEDMode == "Printing" && global.LEDModeLast != "Printing"}		; Enter loop
                    I know it won't loop the homing routine (can work on that next) but theres no point running the other two over and over. Let me know if it works
                    K01571N3Nundefined 1 Reply Last reply Reply Quote 1
                      K01571N3N @jay_s_uk
                      @jay_s_uk the reason for global.LEDModeLast is:
                      Printer is printing -> LEDMode = "Printing"
                      Toolchange comes
                      Toolchange macro
                      set global.LEDMode = "ToolChange"
                      tool change stuff
                      When LEDMode is changed to something from "Printing", it sets LEDModeLast = "Printing"
                        set global.LEDModeLast = "Printing"   <------ here
                      So when the toolchange is completed, LEDMode is back at "Printing" or whatever was the last state of LED, you got the point?
                        jay_s_uk @K01571N3N
                        @k01571n3n yea, but at the end of your tpost, you can just change it back to printing.
                          K01571N3N @jay_s_uk
                          @jay_s_uk yes i can but.. if im not printing, it will change it to wrong mode, thats why there is that last state in memory
                            jay_s_uk @K01571N3N
                            @k01571n3n rather than using a variable, why not just check the printer state? that has different cases like idle, printing, toolchanging etc
                              K01571N3N @jay_s_uk
                              @jay_s_uk but why wouldn’t you want to use variables? i dont get your point for that
                                K01571N3N @K01571N3N
                                @k01571n3n it is so easy to customise almost everything with variables
                                  jay_s_uk @K01571N3N
                                  @k01571n3n look, it was a suggestion. i also said code that i thought would work compared to your code that doesn't. i'm sorry i couldn't help you
                                    K01571N3N @jay_s_uk
                                    @jay_s_uk i understand but that's why i told you why ModeLast exists. and checking printer state is one option too
