Solved [Smart Effector] Heatsink only available?
Hi Duet Team,
I'm using the threaded heatsink on my own effector and want to build a second tool. I already checked the german reseller sites, but no one listed a heatsink only assembly (with nut+washer+ptfe clip)Do you have any hints?
THX
O. Lampe -
@o_lampe the heatsink is now a standard E3D part so it should be available from E3D resellers.
@o_lampe this is the part from E3D https://www.e3d-online.com/products/v6-threaded-heatsink
this one works just as well https://www.aliexpress.com/item/32888313090.html -
Thanks both of you. Order is on it's way!
