CAN Toolboard not triggering pause on extruder temperature fault
Beta Firmware
  • undefined
    brendon
    Last night I had a print fail due to a heater fault on the extruder. Unfortunately the fault on the extruder did not trigger the printer to pause, causing the machine to attempt to continue printing with a cold block. The slowly cooling hotend caused the cold filament to stopped fusing, which then interfered with the part cooling duct/bltouch, ripping them off and breaking them. The machine continued trying to print with a room temperature nozzle for several more hours. I can easily replace those pieces and get back up and running, but I'd like to understand why it happened so I can prevent a repeat.
    The extruder is being ran with a CAN Toolboard v1.1. The machine has a Duet3 mainboard and all the software is the released version of 3.3.
    Current Duet3 version:
    RepRapFirmware for Duet 3 MB6HC 3.4.0 beta 6 (2021-11-06)
    Duet Web Control 3.4.0-b6
    undefined 1 Reply Last reply 20 Jun 2021, 12:57 Reply Quote 0
    • undefined
      brendon @brendon
      Here is my config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 08 2020 13:25:03 GMT-0400 (Eastern Daylight Time)
      M550 P"CustomCore" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M584 X0.1 Y0.2 Z0.5:0.3:0.4 E20.0 ; set drive mapping
      M350 X16 Y16 Z16:16:16 E16 I1 ; configure microstepping with interpolation
      M92 X160 Y160 Z3200:3200:3200 E398 ; set steps per mm
      M566 X600 Y600 Z120:120:120 E300 ; set maximum instantaneous speed changes (mm/min)
      M203 X60000 Y60000 Z600:600:600 E3600 ; set maximum speeds (mm/min)
      M201 X2500 Y2500 Z20:20:20 E5000 ; set accelerations (mm/s^2)
      M906 X1600 Y1600 Z1600:1600:1600 E1400 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X320 Y300 Z300 S0 ; set axis maxima
      M574 X1 S3 ; configure sensorless homing for low end of x
      M574 Y2 S3 ; configure sensorless homing for high end of Y
      M574 Z1 S2; P"io3.in" ; configure Z-probe endstop for low end on Z
      M915 X Y S5 R0 F0
      M558 P9 C"20.io0.in" H5 F360 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      M950 S0 C"20.io0.out" ; create servo pin 0 for BLTouch
      G31 P500 X0 Y-43 Z0.64 ; set Z probe trigger value, offset and trigger height
      M557 X38:295 Y-3:252 P3 ; define mesh grid
      ; leadscrew locations
      M671 X-18:354:169 Y77:77:343 S3
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M143 H0 S150 ; set temperature limit for heater 0 to 80C
      M308 S1 P"20.temp0" Y"pt1000" L-25 ; configure sensor 1 as PT1000 on pin temp1
      M950 H1 C"20.out0" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 A407.5 C228.4 D2.9
      M143 H1 S330
      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
      M950 F1 C"20.out1" ; create fan 1 on pin out4 and set its frequency
      M106 P1 S1 H1 T80 ; set fan 1 value. Thermostatic control is turned on
      ; part cooling ssr
      M950 F2 C"out7"
      M106 P2 S0
      M563 P0 D0 H1 F2 ; define tool 0
      • undefined
        Alex.cr
        I can confirm that I am having the same issue. A temp fault on a V1.1 toolboard running 3.3 does not trigger a pause.
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        undefined 1 Reply Last reply 21 Jun 2021, 07:28 Reply Quote 1
        • undefined
          dc42 administrators @Alex.cr
          @brendon @alex-cr I confirm this is a bug. I have scheduled it for fixing in release 3.4.
          undefined 1 Reply Last reply 21 Jun 2021, 14:16 Reply Quote 1
          • undefined
            brendon @dc42
            @dc42 Thanks for the update, I'll keep an eye on the release notes!
            5 out of 5
