    New core-xy moves wrong
    • Jbournsundefined
      Jbourns
      When i jog the Y axis only the X move to the right. This is my first encounter with a corexy, im not sure whats going one with the odd movements.
      https://drive.google.com/open?id=1vrgOj5paX6L6XUfIhekVto4ogg_T0IHTWg
      Any help is welcome
      [c]
      Config.g
      No recorded activity before August 27, 2017
      All selections cleared All selections cleared
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Sun Aug 20 2017 11:15:55 GMT-0700 (Pacific Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M667 S1 ; Select CoreXY mode
      M208 X350 Y350 Z700 S0 ; Set axis maxima
      M574 X1 Y1 Z2 S1 ; Define active high microswitches
      M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:335 Y15:335 S20 ; Define mesh grid
      M569 P0 S0 ; Drive 0 goes backwards
      M584 X4 Y0 Z2 E3 ; Apply custom drive mapping
      M350 X32 Y32 Z64 E16 I1 ; Configure microstepping with interpolation
      M92 X350 Y350 Z1200 E420 ; Set steps per mm
      M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X800 Y800 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1800 E800 I45 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S10 ; Set idle timeout
      M143 S260 ; Set maximum heater temperature to 260C
      M563 P0 D0 H1 ; Define tool 0
      M550 PCaslte ; Set machine name
      M552 S1 ; Enable network
      M587 SMakerSpace MakerLAN P"aruino1" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      ; Custom settings are not configured[/c]
      • darookeeundefined
        darookee
        I was similarily confused when setting up my CoreXY. Did you read the documentation here https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_CoreXY_printer, espacially the part after the M569 commands and the testing? That helped me getting it right in the end.
        Also there was a change in 1.19 that requires to either swap the X and Y motors or change the directions parameters in the M569 commands for the motors.
        I hope I could help…
