    Define area for mesh compensation missing
    • yagodajmundefined
      yagodajm
      I copied my SD with all my files for my 3D printer. I am going from a single hot end to a dual hot end but wanted to keep most of the settings of the single hot end. The problem I am running into is that I have the mesh defined in my config file, but it is not showing up on the web GUI when I click on the Define area for mesh compensation. Everything worked fine on the original SD card, so I am not sure what I did wrong. mesh config file.PNG Mesh web.PNG Usually it shows what I have in the config settings on the "Set Mesh Parameters"
        @yagodajm I confirm this is a bug in RRF 3.3. The mesh parameters are only reported correctly to DWC after a height map has been probed or loaded.
        yagodajmundefined peter247undefined 2 Replies Last reply Reply Quote 1
        • yagodajmundefined
          yagodajm @dc42
          @dc42 sorry for the late reply, I tried to reply yesterday but kept getting an error to submit. I was able to use an older version of the file to get it to work.
          • peter247undefined
            peter247 @dc42
            @dc42 it is not a bug it's a feature ?.
            When Microsoft does a update which wipes your bios and crashes your computer they call it a new feature .
            Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
