    PT100 daughter board issues
    362
    • Handymanpa54undefined
      Handymanpa54
      I'm running RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
      Duet WiFi Server Version: 1.26
      I was looking over the code and still no luck. The temp shows 2000c but the hotend is cold. There must be some software issue. I used the configurator but somehow things are not right.
        Share your config and a photo of how you have the board setup. Are you sure it's a PT100 sensor?
        Have you seen these?
        https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
        https://duet3d.dozuki.com/Wiki/PT100_temperature_sensor_daughter_board
        Handymanpa54undefined 4 Replies Last reply Reply Quote 0
          Handymanpa54 @Phaedrux
          @phaedrux
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 18 2021 18:18:06 GMT-0400 (Eastern Daylight Time)
          G90                                            ; send absolute coordinates...
          M83                                            ; ...but relative extruder moves
          M550 P"CR-10s Modified"                             ; set printer name
          M552 S1                                        ; enable network
          M586 P0 S1                                     ; enable HTTP
          M586 P1 S0                                     ; disable FTP
          M586 P2 S0                                     ; disable Telnet
          M569 P0 S1                                     ; physical drive 0 goes forwards
          M569 P1 S1                                     ; physical drive 1 goes forwards
          M569 P2 S0                                     ; physical drive 2 goes forwards
          M569 P3 S1                                     ; physical drive 3 goes forwards
          M584 X0 Y1 Z2 E3                               ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00 E420.00              ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                        ; Set idle timeout
          M208 X0 Y0 Z0 S1                               ; set axis minima
          M208 X305 Y305 Z330 S0                         ; set axis maxima
          M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
          M574 Z1 S1 P"zstop"                                     ; configure Z-probe endstop for low end on Z
          M558 P1 C"zprobe.in" H5 F120 T6000             ; set Z probe type to unmodulated and the dive height + speeds
          G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
          M557 X15:215 Y15:195 S20                       ; define mesh grid
          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B0 R0.594 C256.0 D5.32 S1.00           ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                        ; map heated bed to heater 0
          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
          M308 S1 P"spi.cs1" Y"rtd-max31865"                 ; configure sensor 1 as thermocouple via CS pin spi.cs1
          M143 H1 S380                                       ; set temperature limit for heater 1 to 380C
          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1 F0                               ; define tool 0
          G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
          G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
           Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue
          undefined![20210627_190456.jpg](/assets/uploads/files/1624835260427-20210627_190456-resized.jpg)
          The thermistor is Slice engineering PT 100 450c
          I will take a look at the links you posted.
          Mark
              @phaedrux I think a PT100 is an RTD element that is low resistance. I took it out of the circuit and checked resistance with ohmmeter. It looks like an open. I started off without the shorts on the outer pins. I guess There was over voltage applied to it and ruined the Thermistor.
                @phaedrux Hi,
                I did see those links earlier. I just tried a test of that channel. I installed the test resistor and I see -1.3c current temp. I'm trying to get setup to print higher temp filaments. I was thinking about thermocouple as sensor but I couldn't find a daughter board. Maybe PT100 is a better way to go?
                Mark
                  Phaedrux Moderator @Handymanpa54
                  @handymanpa54 said in PT100 daughter board issues:
                  https://www.sliceengineering.com/products/thermistor-high-temperature?variant=36948577452194
                  Is this what you have? This is not a PT100, it's just a high temperature thermistor.
                  To use the PT100 daughterboard you would need a PT100 sensor like this: https://e3d-online.com/products/pt100-temperature-sensor
                  A thermocouple is different as well and has it's own daughterboard:
                  https://duet3d.dozuki.com/Wiki/Thermocouple_daughter_board
                  https://duet3d.dozuki.com/Wiki/Connecting_thermocouples
                  See here for some info on different kinds of temp sensors
                  https://duet3d.dozuki.com/Wiki/Temperature_sensors
                  If you already have the PT100 daughterboard and a hotend that can take a cartridge style sensor, than getting the E3D PT100 sensor is a good option if you want to use high temp materials as it's good up to 500c.
                  Handymanpa54undefined 1 Reply Last reply Reply Quote 0
                    @phaedrux Hi, I think you are correct. I checked back on the order and it is a high temp thermistor. I ordered the one you left a link to, so it should arrive soon. Since the test with a resistor shows near zero I think the software and daughter board are working ok.
