    Duex5 fan voltage
    737
    • reshundefined
      resh
      I have a 12V noctua hotend fan and a 24v parts fan. Is there a jumper on the Duex5 or Duet 2 wifi where I can choose voltage for individual fans? I have a buck converter but I'd rather not have to use it. Thanks for the help.
        jay_s_uk @resh
        @resh no. its a case of VIN or 5v I think but its not on a per fan basis. You'll have to go the buck route
        reshundefined 1 Reply Last reply Reply Quote 0
        • reshundefined
          resh @jay_s_uk
          @jay_s_uk It won't do 12V? I would be bucking the 24V to 12v if I can do that so both fans are on the same voltage.
            jay_s_uk @resh
            @resh the duex will do 12v but the duet 2 won't. so you could split them that way I suppose
            • reshundefined
              resh @jay_s_uk
              @jay_s_uk So I could do the 12v fan on the duex5 and the 24v fan, (which is VIN) to the duet 2 and I wouldn't need the bucking buck converter?
                jay_s_uk @resh
                @resh correct
                • reshundefined
                  resh @jay_s_uk
                  @jay_s_uk I've got these wired. Part fan is in F0 on Duet and hotend fan is in F3 on Duex5. First time dealing with fans but it looks correct to me. I want the hotend fan always on. I can't get hotend fan to turn on.
                  version 3.3
                  M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                  M950 F3 C"fan3" Q500                           ; create fan 1 on pin fan1 and set its frequency
                  M106 P3 S1 H-1                              ; set fan 1 value. Thermostatic control is turned on
                    jay_s_uk @resh
                    @resh said in Duex5 fan voltage:
                    M950 F3 C"fan3" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P3 S1 H-1
                    The M106 should be
                    M106 P3 S1 H1 T45 assuming H1 is the heater number
                    • reshundefined
                      resh @jay_s_uk
                      @jay_s_uk said in Duex5 fan voltage:
                      The M106 should be
                      This will turn hotend fan on when needed instead of on all the time?
                        Yes it will turn on fan3 when heater1 is over 45c.
                        • reshundefined
                          resh @Phaedrux
                          @phaedrux Thanks for the help. I'm not getting fan3 to turn on when heater1 is over 45c. The part fan is always on so something might be wrong there.
                          On duet I have the fan jumper on V_fan and VIN, and the part fan(24v) is connected to FAN0. On the duex5 I have the jumper on 12V and the hotend fan(12V) connected to FAN3.
                          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Feb 26 2021 10:46:02 GMT-0500 (Eastern Standard Time)
                          G90                                            ; send absolute coordinates...
                          M83                                            ; ...but relative extruder moves
                          M550 P"My Printer"                             ; set printer name
                          M552 S1                                        ; enable network
                          M586 P0 S1                                     ; enable HTTP
                          M586 P1 S0                                     ; disable FTP
                          M586 P2 S0                                     ; disable Telnet
                          M569 P0 S1                                     ; physical drive 0 goes forwards s1 is forward s0 backwards
                          M569 P5 S1
                          M569 P6 S0                                     ; physical drive 1 goes forwards
                          M569 P2 S1                                     ; physical drive 2 goes forwards
                          M569 P3 S1
                          M569 P4 S1
                          ; physical drive 3 goes forwards
                          M584 X0 Y5:6 Z2:4 E3						   ; set drive mapping
                          M671 X-20:290 Y0:0 S5 							;leadscrews at left (connected to Z) and right (connected to E1) of X axis
                          M208 X10:300 Y0:180								;X carriage moves from -5 to 270, Y bed goes from 0 to 130
                          M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                          M92 X80.00 Y53.33 Z397.6143 E420.00              ; set steps per mm
                          M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
                          M203 X6000.00 Y6000.00 Z400 E1200.00        ; set maximum speeds (mm/min)
                          M201 X600.00 Y600.00 Z100 E250.00            ; set accelerations (mm/s^2)
                          M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30                                        ; Set idle timeout
                          M208 X0 Y0 Z0 S1                               ; set axis minima
                          M208 X310 Y310 Z180 S0                         ; set axis maxima
                          M574 X2 S1 P"!xstop"                           ; configure active-high endstop for high end on X via pin !xstop
                          M574 Y2 S1 P"!ystop+!e0stop"                           ; configure active-high endstop for high end on Y via pin !ystop
                          M574 Z2 S2                                     ; configure Z-probe endstop for high end on Z
                          ; Z-Probe                        ; create servo pin 0 for BLTouch
                          M558 P9 C"^zprobe.in" H5 F120 T6000  ; set Z probe type to bltouch and the dive height + speeds
                          M950 S0 C"duex.pwm5"
                          G31 P500 X-31.5 Y7 Z4.627                            ; set Z probe trigger value, offset and trigger height
                          M557 X0:155 Y0:155 S20                       ; define mesh grid
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                          M307 H0 R0.135 C738.7 D1.34 S1.00 V23.5     ; enable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                        ; map heated bed to heater 0
                          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8  ; configure sensor 1 as thermistor on pin e0temp
                          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                          M307 H1 B0 R2.039 C177.8 D6.23 S1.00 V24.0     ; disable bang-bang mode for heater  and set PWM limit
                          M143 H1 S285                                   ; set temperature limit for heater 1 to 280C
                          M106 P0 S1 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                          M106 P3 S1 H1 T45                             ; set fan 1 value. Thermostatic control is turned on
                          M563 P0 D0 H1 F0 S"Extruder"                              ; define tool 0
                          G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                          G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                          M575 P1 S1 B57600 ;enable support for PanelDue
                          T0						; Select first tool
                            Phaedrux Moderator @resh
                            Change fan3 to duex.fan3
                            reshundefined 1 Reply Last reply Reply Quote 1
                            • reshundefined
                              resh @Phaedrux
                              @phaedrux said in Duex5 fan voltage:
                              No luck with the change. I checked wiring again and it looks good.
                              M569 P5 S1
                              M569 P3 S1
                              M569 P4 S1
                              M203 X6000.00 Y6000.00 Z350 E1200.00        ; set maximum speeds (mm/min)
                              M201 X600.00 Y600.00 Z90 E250.00            ; set accelerations (mm/s^2)
                              M950 F3 C"duex.fan3" Q500                           ; create fan 1 on pin fan1 and set its frequency
                                If you send M106 P3 S1 H-1 does the fan turn on?
                                • reshundefined
                                  resh @Phaedrux
                                  @phaedrux No, it didn't turn on
                                    Are you sure you're connected to fan3 on the Duex?
                                    Can you try with a different Duex fan port?
                                    Does that fan work at all?
                                    • reshundefined
                                      resh @Phaedrux
                                      @phaedrux Changed to F4 but I also checked voltage out of the pins when hotend was above 45 and I'm getting no voltage. It's a brand new board. Also checked the jumper connection and it's good.
                                        Are you saying it worked on fan4?
                                        • reshundefined
                                          resh @Phaedrux
                                          @phaedrux Sorry, it did not work on fan4. No voltage out of any fan headers on duex.
                                            dc42 administrators @resh
                                            @resh what position do you have the DueX fan voltage selection jumper in? If it's in the 12V position, have you fitted the 12V regulator enable jumper?
