Fan Gcode print end
274
  • undefined
    Auré
    Hello!
    Sorry, I search how to stop the print fan.
    I test M107 but don't work.
    I test M106 S0 but don't work
    I see on https://reprap.org/wiki/G-code
    Alternatively be specified as a real fraction: M106 S0.7
    I test M106 S0.7 but don't work.........
    Someone can give me a tips please?
    My Gcode for print end:
    G91 ;Relative positioning
    G1 E-2 F2700 ;Retract a bit
    G1 E-2 Z1 F2400 ;Retract and raise Z
    M106 S0.7
    G90
    G1 X355 Y340 F3000 ;Wipe out
    M117 Fin d'impression
    Reprap core XY, Ender 3 upgraded.
    If you keep trying, you'll eventually succeed. So: the more you fail, the more likely you are to succeed.
    A quote from Jacques Rouxel
    • undefined
      Are you sure your fan is connected to a controllable fan port and not an always on fan port?
      Use this as your gcode dictionary for reprapfirmware: https://duet3d.dozuki.com/Wiki/Gcode
      undefined 1 Reply Last reply 2 Jul 2021, 16:35 Reply Quote 0
      • undefined
        Auré @Phaedrux
        @phaedrux I had used this https://duet3d.dozuki.com/Wiki/Gcode#Section_M107_Fan_Off
        but when I saw that it didn't work I looked elsewhere on the internet.
        The fan is connect to the controllable fan port because her speed can be change.
        • undefined
          Post your config.g please so I can see the fan and tool definitions.
          undefined 1 Reply Last reply 2 Jul 2021, 16:42 Reply Quote 0
          • undefined
            Auré @Phaedrux
            @phaedrux Yep thanks:
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 04 2021 20:14:20 GMT+0200 (heure d’été d’Europe centrale)
            M550 P"Mon imprimante Duet 3" ; set printer name
            M552 S4
            M669 K1 ; select CoreXY mode
            G4 S4 ;wait for expansion boards to start
            M569 P0.0 S0 ; physical drive 0.0 goes forwards
            M569 P0.1 S0 ; physical drive 0.1 goes forwards
            M569 P0.3 S0 ; physical drive 0.3 goes forwards
            M569 P0.4 S0 ; physical drive 0.4 goes forwards
            M569 P0.5 S0 ; physical drive 0.5 goes forwards
            M569 P121.0 S1 ; physical drive 121.0 goes forwards
            M584 X0.0 Y0.1 Z0.3:0.4:0.5 E121.0 ; set drive mapping
            M671 X-18.109:183.1:384.309 Y-10.413:367.797:-10.413 S50
            M92 X160.00 Y160.00 Z800.00 E335.40 ; set steps per mm
            M566 X1200.00 Y1200.00 Z30.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X1600.00 Y1600.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1200 E840 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X365 Y355 Z335 S0 ; set axis maxima
            M574 X1 S1 P"121.io1.in" ; configure active-high endstop for low end on X via pin 121.io1.in
            M574 Y1 S1 P"io0.in" ; configure active-high endstop for low end on Y via pin io0.in
            M574 Z1 S2 ; configure Z-probe endstop for low end on Z
            M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
            M558 P9 C"^121.io0.in" H15 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X3 Y-41 Z3.569 ; set Z probe trigger value, offset and trigger height
            M557 X15:215 Y15:195 S20 ; define mesh grid
            M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
            M143 H0 S100 ; set temperature limit for heater 0 to 100C
            M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
            M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
            M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
            M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
            M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
            M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
            M563 P0 D0 H1 F0 F1 ; define tool 0
            undefined 1 Reply Last reply 2 Jul 2021, 16:45 Reply Quote 0
            • undefined
              Phaedrux Moderator @Auré
              @auré said in Fan Gcode print end:
              There is a problem with your fan definitions. Fan0 is setup as a thermostatically controlled fan. Fan1 is gcode controllable, but BOTH fans have been assigned to the tool as part cooling fans.
              Remove the F0
              undefined 1 Reply Last reply 2 Jul 2021, 16:48 Reply Quote 0
              • undefined
                Auré @Phaedrux
                @phaedrux said in Fan Gcode print end:
                Ok thanks I test when my current print is finished and I tell you 🙂
                • undefined
                  Auré
                  Ok it's works! Thank you! 🙂
                  1 out of 8
