Home not stored
Hey Guys,
I'm having an issue with homing after upgrading to version 3.3. My machine homes all three axis successfully using the home all button but returns to "The following axes are not homed: X, Y, Z" once homing completes and the steppers are released.
My best guess is there's a command that I'm missing, but I've been unable to find it in the Gcode dictionary. I've searched for similar issues on the forum without any luck there either.
Thanks for any suggestions!
Bear
@bvi8370 can you post your homing files please. Can you also confirm your firmware version using M115
@bvi8370 said in Home not stored:
What do you mean by this?
Post your config.g as well. Do you have a idle current set to 0?
Do you mean using M18 to disable the steppers?
IF so that is the cause and it is the expected result of using M18.
Hi guys. I've tried to provide answers below.
Here's my config.g:
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 02 2021 16:03:43 GMT-0400 (Eastern Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"ENDER 3" ; set printer name M555 P2 ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S1 ; enable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes backwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I0 ; set motor currents (mA) and motor idle factor in per cent M84 S10 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X220 Y220 Z250 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" M574 Y1 S1 P"ystop" ; set active high endstops M574 Z1 S2 ; set endstops controlled by probe ; Z-Probe ;M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch M950 S0 C"exp.heater3" M280 P0 S80 M558 P3 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z0.168 ; set Z probe trigger value, offset and trigger height M557 X38:220 Y24:220 S50 ; define mesh grid ; Heaters ;*Bed M308 S0 P"bedtemp" Y"thermistor" T100000 R4700 ; set thermistor + ADC parameters for heater 0 M950 H0 C"bedheat" T0 M307 H0 A240.3 C608.7 D8.2 V24.1 B0 S1; ADC correction M140 H0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 p"e0temp" Y"thermistor" T100000 B4138 M950 H1 C"e0heat" T1 M307 H1 A270.7 C90.4 D6.7 V24.0 B0 S1 ; ADC correction M143 H1 S280 ; set temperature limit for heater 1 to 280C ; ;M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M570 S360 ; Fans M950 F0 C"fan0" Q500 M106 P0 S0 H-1 M950 F1 C"fan1" Q500 M106 P1 S1 H1 T70 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
Here's homeall.g:
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 02 2021 16:03:43 GMT-0400 (Eastern Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-225 Y-225 F300 ; move slowly to X and Y axis endstops once more (second pass) ; absolute positioning G1 X38 Y24 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
Homex.g:
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 02 2021 16:03:44 GMT-0400 (Eastern Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-225 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F6000 ; go back a few mm G1 H1 X-225 F300 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
Homey.g:
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 02 2021 16:03:44 GMT-0400 (Eastern Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y-225 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y5 F6000 ; go back a few mm G1 H1 Y-225 F300 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
homez.g:
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 02 2021 16:03:44 GMT-0400 (Eastern Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X38 Y24 F6000 ; go to first probe point G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
Result of M115:
M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
During the home all process, each axes turns blue in the web console and the message "The following axes are not homed" disappears. Then there is about a 10 second delay. Then all the steppers disable (so the axis can be moved manually), and the message "The following axes are not homed: X, Y, Z" appears again. The machine doesn't remember that it just homed all the axis.
I'm not using M18 to disable the steppers. I'm just clicking the home all button in the web console.
Thanks again!
You've set the idle current to go to 0 after 10 seconds. Hence why it unhomes. Change the I value to 30
Be very careful if you do move them "manually" - moving them will generate a voltage from the stepper which can damage the stepper driver chip on the Duet.
Move them slowly - very slowly.
@fcwilt
Thanks. I learned this the hard way when I bought my first Ender 3 a couple years ago - smoked the board instantly! -
Thank you! This fixed it!
