cant get my reprap smart display to work on my maestro
its just supposed to plug in and i issue M918 S1 and it should do something no? Ive tried flipping the 10 pin cables as they sometimes are flipped and it just lights up the screen when i swap that cable and thats is, ive uploaded menu files:(https://github.com/jadonmmiller/UltimateDuetMenuSystem/releases) to try and see if i need them for the display to show something and nothing. when i send m918 is it supposed to return anything in the console? ive done the commands from my pc and from the web interface, ive just updated to the newest firmware
@jcwild its a reprap graphic smart display, the 12864
From the docs:
There are two types of controller chip commonly used in these controllers: ST7920 and ST7567.
The ST567 requires a "modified wiring loom" - whatever that means.
@jcwild said in cant get my reprap smart display to work on my maestro:
When I first tried it, I used a second SD card in the reader of the display => WRONG
Then I made a 'menu' subdirectory in the /sys folder of the main SD-reader => WRONG
Then I made a 'menu' folder in the root directory of the main SD-reader => BINGO
