    G29 on a delta, no probe offset?
    • ESTIMULOundefined
      ESTIMULO
      Hello, I am working with a delta machine and a bltouch probe.
      The probe offset is X-40 from the nozzle (I set it up in my G31 X-40 Y0 Z2.32 P25).
      Here http://escher3d.com/pages/wizards/wizardbed.php i can set my probe offset and the test points seems to be perfect for G32 but, is there any way to indicate my probe offset for bed meshing? (G29).
      I can set only printable radius and distance from probes but not where to probe:
      M557 R110 S20
      so when is running G29, with the left points, bltouch is outside of the bed.
      Thanks and sorry my english.
        Check that you don't have another G31 command in bed.g that sets the probe offset to zero. This was required with some old firmware versions, but isn't any more.
