Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you have been placed in read-only mode.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
Hello guys, Do I need any resistor or diode to the output of the sensor to connect an NPN NO inductive sensor to the z probe?
@sarvan
What board are you using?
@fcwilt Duet2wifi
@sarvan Looks like you don't need a diode unless your Duet2 WiFi is revision 1.03 or earlier.
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
