Issue after updating Duet 3 to RRF3.3
Hello, I updated my Duet 3 to RRF 3.3 from SBC terminal with command:
sudo apt-get update && sudo apt-get upgrade duetsoftwareframework
And after that my Duet web server looks like this:
It worked in the previous firmware, but now I cannot even control my motors. I tried to reset the board to the factory settings from the server and also tried to reconfigure my setup from RRF Config tool. How do I fix this? -
Try running the following code and report any warnings or responses:
M98 P"config.g"
Also please post your config.g and the response to to an M122 command.
@dkkovalev said in Issue after updating Duet 3 to RRF3.3:
What do you mean by this?
What firmware version were you running before?
@phaedrux
I clicked on Revert to factory defaults from General tabFirmware version i was running was the stock one from 2019 when I bought the board (I didn't manage to get what exact version that was)
Running
M98 P"config.g"
Did nothing to me.
After running
M122
I've got this error message:
Warning: Incompatible firmware, please upgrade as soon as possible My g code:
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Jul 11 2021 22:49:11 GMT+0300 ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name M669 K1 ; select CoreXY mode ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S0 ; physical drive 0.2 goes backwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M584 X0.0 Y0.1 Z0.2 E0.5 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X550 Y350 Z400 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io2.in" ; configure active-high endstop for low end on X via pin io2.in M574 Y1 S1 P"io5.in" ; configure active-high endstop for low end on Y via pin io5.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"io7.out" ; create servo pin 0 for BLTouch M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:550 Y15:350 S50 ; define mesh grid ; Heaters M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp0 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@dkkovalev You're running an outdated firmware version. Please try to send
M997
from the web interface to update the firmware (either at the top or on the Console page). The "Revert to factory defaults" link is only applicable to DWC. -
@chrishamm
M997 returns Error: M997: No boards have been detected to me -
@dkkovalev In that case your board firmware version is probably too old (< 3.2-b4). Please send
M999 P"ERASE"
and check out this guide to install the latest firmware via USB. -
@chrishamm
Thanks, it worked! -
Now I have a strange issue with my BLTouch. It keeps deploying and retracting after any error
@dkkovalev please start a new thread for that issue.
