How to manage multi-tool cnc
I would like to use multi tool for cnc use.
For now I change my tool manually. I can know each offset of my tools due to tool holders.
How can I config my config.g ?For now I've create 10 tools with M563.
The problem is, if I use a tool probe or change the offset with G30 or G10... this offset will disappear on each restart.
There is a solution to avoid this ? In the 3.4 firmware is that possible to implement a file call maybe tool.csv like filament.csv to keep tool offset in memory ?
Thanks !
@tom33 you can use M500 P10 to save parameters including all tool offsets in config-override.g.
