Duet3 3HC: Critical mistake in wiring diagram
Hey,
after taking measurements on the board for finding the problem regarded in my other thread I noticed that the connections of out0 to out2 are swapped.
Taking a multimeter and testing the connections of the header against Vin I have a connection from the pins marked "PWM_Vin" to Vin, and no connection to Vin on the Pins marked V_FUSED.
So if I didn't got the diagram wrong, there is a mistake, which can lead to wrong polarity on the connected parts.
My board is V1.0
It would be good if someone could also check this on his bord to verify the problem.
JNB
@jnb thanks for pointing this out, its updated here:
https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_3HC_Wiring_Diagram
