    RRF install failure with Hardkernel Odroid C4 as the SBC
    Firmware installation
    841
    • Nurgelrotundefined
      Nurgelrot
      Trying to get RRF 3.3 working on a Odroid C4. I've followed the instructions for turning on SPI and compiled and successfully run their little test program. /dev/spidev0.0 seems to be working. I have the bufsize set to 8192 for the spidev
      But when install RRF I get:
      [fatal] Could not connect to Duet (Error 16. Cannot put line into event mode.) when the actual firmware package kicks off.
      Is this something to do with the SPI bus or is this due to not correctly setting the transfer ready pin? Basically what might be throwing this error. I know I'm trying to so stuff way out side the normal support lanes here just need to know where to go looking...
      I'm doing the bulk of my testing with a BTT GTR board the STM port (just incase I really mess something up). But I get the same error when attaching a genuine Mini5.
      Attaching information that maybe helpful to people looking into this...
      root@odroid:~# ls -al /dev/i2c* /dev/spi* /dev/ttyS* /dev/gpio*
      crw-rw---- 1 root gpio    254, 0 Jul 17 23:37 /dev/gpiochip0
      crw-rw---- 1 root gpio    254, 1 Jul 17 23:37 /dev/gpiochip1
      crw-rw---- 1 root root    242, 0 Jul 17 23:37 /dev/gpiomem
      crw------- 1 root root     89, 0 Jul 17 23:37 /dev/i2c-0
      crw------- 1 root root     89, 1 Jul 17 23:37 /dev/i2c-1
      crw-rw---- 1 root gpio    153, 0 Jul 17 23:37 /dev/spidev0.0
      crw--w---- 1 root tty     239, 0 Jul 17 23:37 /dev/ttyS0
      crw-rw---- 1 root dialout 239, 1 Jul 17 23:37 /dev/ttyS1
      crw-rw---- 1 root dialout 239, 2 Jul 17 23:37 /dev/ttyS2
      crw-rw---- 1 root dialout 239, 3 Jul 17 23:37 /dev/ttyS3
      root@odroid:~# lsmod | grep spi
      spidev                 20480  0
      spi_meson_spicc        20480  0
      root@odroid:~# gpio readall
       +-----+-----+---------+------+---+--- C4 ---+---+------+---------+-----+-----+
       | I/O | wPi |   Name  | Mode | V | Physical | V | Mode |  Name   | wPi | I/O |
       |     |     |    3.3V |      |   |  1 || 2  |   |      | 5V      |     |     |
       | 493 |   8 |   SDA.2 | ALT1 | 1 |  3 || 4  |   |      | 5V      |     |     |
       | 494 |   9 |   SCL.2 | ALT1 | 1 |  5 || 6  |   |      | 0V      |     |     |
       | 481 |   7 |  IO.481 |   IN | 1 |  7 || 8  | 1 | ALT1 | TxD1    | 15  | 488 |
       |     |     |      0V |      |   |  9 || 10 | 1 | ALT1 | RxD1    | 16  | 489 |
       | 479 |   0 |  IO.479 |   IN | 1 | 11 || 12 | 1 | IN   | IO.492  | 1   | 492 |
       | 480 |   2 |  IO.480 |   IN | 1 | 13 || 14 |   |      | 0V      |     |     |
       | 483 |   3 |  IO.483 | ALT2 | 1 | 15 || 16 | 1 | IN   | IO.476  | 4   | 476 |
       |     |     |    3.3V |      |   | 17 || 18 | 1 | IN   | IO.477  | 5   | 477 |
       | 484 |  12 |    MOSI | ALT4 | 0 | 19 || 20 |   |      | 0V      |     |     |
       | 485 |  13 |    MISO | ALT4 | 0 | 21 || 22 | 1 | IN   | IO.478  | 6   | 478 |
       | 487 |  14 |    SLCK | ALT4 | 0 | 23 || 24 | 1 | OUT  | SS      | 10  | 486 |
       |     |     |      0V |      |   | 25 || 26 | 0 | ALT2 | IO. 23  | 11  | 433 |
       | 474 |  30 |   SDA.3 | ALT2 | 1 | 27 || 28 | 1 | ALT2 | SCL.3   | 31  | 475 |
       | 490 |  21 |  IO.490 |   IN | 1 | 29 || 30 |   |      | 0V      |     |     |
       | 491 |  22 |  IO.491 |   IN | 1 | 31 || 32 | 1 | ALT2 | IO. 24  | 26  | 434 |
       | 482 |  23 |  IO.482 | ALT2 | 1 | 33 || 34 |   |      | 0V      |     |     |
       | 495 |  24 |  IO.495 |   IN | 0 | 35 || 36 | 1 | OUT  | IO. 22  | 27  | 432 |
       |     |  25 |   AIN.2 |      |   | 37 || 38 |   |      | 1V8     | 28  |     |
       |     |     |      0V |      |   | 39 || 40 |   |      | AIN.0   | 29  |     |
      root@odroid:~# cat /opt/dsf/conf/config.json
        "PluginSupport": true,
        "RootPluginSupport": false,
        "PluginsFilename": "/opt/dsf/conf/plugins.txt",
        "LogLevel": "info",
        "SocketDirectory": "/var/run/dsf",
        "SocketFile": "dcs.sock",
        "Backlog": 4,
        "SocketPollInterval": 2000,
        "BaseDirectory": "/opt/dsf/sd",
        "PluginDirectory": "/opt/dsf/plugins",
        "NoTerminateOnReset": false,
        "HostUpdateInterval": 4000,
        "MaxMessageAge": 60,
        "SpiDevice": "/dev/spidev0.0",
        "SpiBufferSize": 8192,
        "SpiTransferMode": 0,
        "SpiFrequency": 8000000,
        "SpiConnectTimeout": 500,
        "SpiTransferTimeout": 500,
        "SpiConnectionTimeout": 4000,
        "MaxSpiRetries": 3,
        "SpiPollDelay": 25,
        "GpioChipDevice": "/dev/gpiochip0",
        "TransferReadyPin": 6,
        "BufferedPrintCodes": 32,
        "BufferedMacroCodes": 16,
        "MaxBufferSpacePerChannel": 1536,
        "MaxCodeBufferSize": 256,
        "MaxMessageLength": 4096,
      ... cutting off here as the rest isn't useful.
      Thanks
      Nurgelrotundefined 1 Reply Last reply Reply Quote 0
        Nurgelrot @Nurgelrot
        @nurgelrot Talking to myself here.. running DuetControlServer -l trace tells me it's the GPIO transfer ready pin. But man I wish I understood how to pass it the right values. The "6" value above would only work if I'd compiled DCS linking to the WiringPI wrapper library. But '478' which is how the Odriod thinks of it doesn't work either so maybe this is a lost cause...
          Nurgelrot
          I got it... I love it when a plan comes together... Found the correct GPIO pin:
          #68 located in device /dev/gpiochip1
          thanks for putting up with my noise everyone 🙂
          If you have one of these SBC's feel free to hit me up if you run into issues.
          o_lampeundefined joekoundefined 2 Replies Last reply Reply Quote 2
          • o_lampeundefined
            o_lampe @Nurgelrot
            @nurgelrot
            A while ago I asked about Odroid support and was linked to a readme file where all supported MPUs were listed. Odroid N2 was not.
            Did that change over time? Or did you make your own DSC image?
              Nurgelrot @o_lampe
              @o_lampe No I have it working now with both the Hardkernel Ubuntu release and the Armbian release for the C4. No extra compiling required. Just followed the guide on setting up an SBC for Duet and improvising as needed. Getting the buffersize for SPI is a little tricky as it wont pick it up from modprobe. you have to pass it as a boot time param in the bootargs of the kernel (spidev.bufsiz=8192)
              I'm really liking this board so far. Almost the same form factor as the pi3 just the HDMI port is moved and the power connector is different. Its 12v instead of 5 runs 15c cooler than the pi4 but still has the standard 5v outputs. Also has separate input for the tty console (in addition to UARTs on the 40pin) has option to hardwire to a PSU rather than the bulky barrel connector.
              No WiFi/BT though, but given my experiences with the WiFi in the Pi that might actually be a benefit... 4 USB3 ports so a wifi dongle is no big deal and works better than a built in one anyway. Has the option to run of an eMMC chip or an SD card so "disk" IO isn't an issue.
              Now I just have to run it for awhile and see if RRF play's nice with it.
              https://www.cnx-software.com/2020/04/24/raspberry-pi-4-vs-odroid-c4-features-comparison/
              • joekoundefined
                joeko @Nurgelrot
                @nurgelrot said in RRF install failure with Hardkernel Odroid C4 as the SBC:
                hallo,
                i am going to do the same with a duet3 mini and a odroid c4. how you did this ? did you modify the cable or create an new one ?
                you wrote that gpio pin #64 is right. why is this the right pin ? i cant find this pin on the odroid wiki.
                  Nurgelrot @joeko
                  @joeko I find its easiest to use a linux distro that is still using the version 4.9 kernels. And you do not need any custom cable the one that comes with the Duet works fine.
                  First install/configure your OS and then add the gpiod package. Then run gpioinfo and you will see how the Odroid is maping the standard Pi gpio pins. The SPI stuff should be fine by default but you need to find where PI pin 22 goes. pin 22 on the standard Pi gpio header maps on the Odroid C4 as below on ubuntu focal or debian bullsye based installs:
                  root@# gpioinfo
                  gpiochip0 - 16 lines:
                  gpiochip1 - 86 lines:
                          line  68:     "PIN_22"       unused   input  active-high
                  So install the duet software as normal and it will error out due to the config being wrong. Then edit
                  and replace the lines for:
                  "GpioChipDevice": "/dev/gpiochip1",
                    "TransferReadyPin": 68,
                  Your's may be diffrent depending on what the output of gpioinfo was. then reinstall the duet software and it should make the connection the board and start up.
                  You'll also have to adjust the SPI Buffer by adding
                  options spidev bufsiz=8192
                  to
                  /etc/modprobe.d/spidev.conf
                  Reboot the Odroid and all should work just like the Pi. If for some reason the Duet software is messed up from the failed install just reinstall.
                  joekoundefined 1 Reply Last reply Reply Quote 0
                  • joekoundefined
                    joeko @Nurgelrot
                    root@# gpioinfo
                    to
                    yes i got it 🙂
                    thx
                    but on odroid buster i cant find
                    i set "spidev bufsiz=8192" in the boot.ini (bootsarg)
                    is this o or should i create the spidev.conf ?
                      Nurgelrot @joeko
                      @joeko Setting it as an argument to boot is fine too if that's working for you.
                      • joekoundefined
                        joeko @Nurgelrot
                        thank you 🙂
                        i like odroid sbc. running with emmc and with Exec On MCode setting i shut down the sbc with M7722
                        • o_lampeundefined
                          o_lampe @joeko
                          @joeko said in RRF install failure with Hardkernel Odroid C4 as the SBC:
                          Shut down isn't hard, but how do you restart it? I have an remote controlled mains adapter to switch the odroid powersupply off/on to restart...
                          Nurgelrotundefined joekoundefined 2 Replies Last reply Reply Quote 0
                            Nurgelrot @o_lampe
                            @o_lampe Simple I never turn mine off 🙂 use the odroid and Node-RED to run all the relays to start the printers/cameras etc... So at least one SBC is always on- usually just leave them all on and power down the printers.
                            • joekoundefined
                              joeko @o_lampe
                              @o_lampe said in RRF install failure with Hardkernel Odroid C4 as the SBC:
                              you can restart the sbc also on this way. create an new service and call him reboot. modify the lines from poweroff to reboot andfrom M7722 to M7723 and than you can reboot with M7723. also updates over the sbc should be possible
