    Pin name for extruder driver on Toolboard 1.1
    • kb58undefined
      kb58
      Looking here: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names
      I see the following pin names for the tool board IO:
      out0
      out1
      out1.tach
      out2
      out2.tach
      io0.out
      io0.in
      io1.in
      io2.in
      temp0
      temp1
      button0
      button1
      My question is, what is the extruder driver output named? I've made a few guesses and so far it's not seeing it.
      Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
      PaulHewundefined 1 Reply Last reply Reply Quote 0
      • PaulHewundefined
        PaulHew @kb58
        @kb58 My 1LC is CAN Id 20
        Config for the extruder is
        M569 P20.0 S0                                    ; Extruder - physical drive 20.0 goes forwards
        So ##.0
        HTH,
        Paul
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        • kb58undefined
          kb58
          Thank you very much... man, I wouldn't have guessed that for a long time!
          • kb58undefined
            kb58
            I would have bet money that changing the port name to that would have fixed it... and lost that bet...
            Checked the wiring and connections about 10 times, and the board still isn't seeing the stepper. I shall beat this thing, one way or another!
            • PaulHewundefined
              PaulHew @kb58
              @kb58 Make sure you have mapped the drive also....
              M584 X0.0 Y0.1 Z0.2:0.3:0.4 E20.0                ; set drive mapping
              So M584 E20.0 in my case.
              P.
              kb58undefined 1 Reply Last reply Reply Quote 0
              • PaulHewundefined
                PaulHew
                ....and make sure the firmware matches on both the 1LC and your mainboard.
                m122 b20
                Diagnostics for board 20:
                Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
                m122
                RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus Ethernet (SBC mode)
                • kb58undefined
                  kb58 @PaulHew
                  @paulhew said in Pin name for extruder driver on Toolboard 1.1:
                  That was it! Thank you very much; I think I've been staring at this too long today
