Solved Bed thermistor give me wrong value
Hello, the thermistor of the heated bed give me really strange values. I don't put the heater on and it goes from 200°C to 450°C and it vary a lot.
I checked the resistance with a multimeter and it's around 98k at 25°C ambiant temperature. It's connected to "TEMP 0" input on my Duet 3 Standalone. I don't think the problem is the wiring as if I'm correct the thermistor is not polarized.Here's the config for this part :
; HEATERS ; H0 Bed M308 S0 P"0.temp0" Y"thermistor" A"Bed" T100000 B4138 C0 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"0.out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C
It seems correct to me but maybe I'm wrong.
@e4d said in Bed thermistor give me wrong value:
Instead of 0.temp0, change it to temp0
and the same with out0Just a suggestion.
P.
@e4d I suspect there is an intermittent short circuit between one of the thermistor wires and something else, perhaps the hot end metalwork.
@dc42 this is the problem, thank you. I will try to repair it
