    Scary moment with two-pin jumper
    • kb58undefined
      kb58
      Mentioning this for other users:
      During setup and configuration of a board, a 2-pin jumper was plugged in briefly, then removed. Later, I realized that it needed to be permanently installed and went to reinsert it, but noticed that the 2-pin jumper was now an empty plastic shell, and that the metal pin assembly had pulled out and was laying loose on the powered-up electronics, yikes!
      Fortunately nothing was damaged, but it was pure random chance where it landed. So summed up: Be careful when using 2-pin headers, because the internal pins are not always captive. I've had that happen before, but usually they stay put on the male board pins, but not this time!
      Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @kb58
        @kb58 Yikes!
