G-Code Meta commands: Option unset (all) globals
Firmware wishlist
1.0k
  • undefined
    oliof
    I am working on some tricks with globals in config.g, but this doesn't work very straightforwardly because I get errors redefining globals (as documented).
    For easier testing (including retaining the ability to call M98 P"config.g without getting errors from previously defined globals), it would be great to unset all globals without going through a full board reset (which takes up to two minutes with network reset and WiFi negotation and whatnot), and those minutes add up quickly when iterating.
    So I propose a unset [params|vars|globals|all|specific variable] command to allow for faster tweaking and returning to a blank slate than a full board reset during which I might not even see how my modified gcode fails.
    undefined undefined 2 Replies Last reply 20 Jul 2021, 02:24 Reply Quote 0
    • undefined
      OwenD @oliof
      @oliof
      Resetting the global value and avoiding the errors when running M98 P"config.g" is as simple as checking if the global already exists.
      My config.g and other macros are done like this for all variables.
      if !exists(global.HeaterCheckInterval)
      	global HeaterCheckInterval=10 ; create variable for use in daemon.g sets interval of heater checks
      else
      	set global.HeaterCheckInterval=10 ; reset variable for use in daemon.g sets interval of heater checks
      I'm not sure what you mean by "unset"
      Do you me the free the memory allocated to the variable and delete it from the object model?
      undefined 1 Reply Last reply 20 Jul 2021, 02:36 Reply Quote 1
      • undefined
        fcwilt @OwenD
        @owend said in G-Code Meta commands: Option unset (all) globals:
        Checking could become cumbersome if you have dozens of variables.
        Being unable to "undefine" global variables is not a bad idea.
        undefined 1 Reply Last reply 20 Jul 2021, 18:36 Reply Quote 0
        • undefined
          oliof @fcwilt
          @fcwilt exactly. Just for the basic values of a typical printer (axis minima and maxima, probe offsets for z probe, endstop configuration) to automate homing and bed leveling gets me to a dozen variables. And I haven't even touched "interesting" stuff
          • undefined
            egmrudd @oliof
            If you unset everything, then you have to rerun config.g(which requires a board restart) or run the sys and macro files where they are first initialized one by one to recreate those variables again. I don't see how that is less tedious than just checking existence. Also I would recommend not defining anything you plan on changing often in the config.g. Just make a file in the sys directory that gets loaded when config.g is run on startup via M98. That way if you want to change something after config.g runs, you don't have to rerun it, you just rerun that specific file. For example I have motor settings in a file outside the config.g. That way I can turn down max accelerations during homing, then just revert to my default settings by running M98 P"motorSettings.g" at the end of the homing sequence. Or I can edit it and rerun to change my default motor settings without a board restart and those changes will be persistent on future restarts.
            I partially agree with this feature, because it would be occasionally useful to nuke a global variable, but if you are unsetting specific variables, that is just as tedious as checking for the variables existence. Also what happens if you try to unset a variable that does not exist?
            Here is a common example of how I handle variables that get modified in various locations. This actually stored in a 0:\sys file named probeLocation.g I created and gets initially run by config.g but I can modify this and run it without a restart.
            ;store values locally while existence is checked
            var probeLocationX = XX.XX
            var probeLocationY = YY.YY
            var probeLocationZ = ZZ.ZZ
            if exists(global.probeLocationX) == true
                ;if true REdefine probelocations
                set global.probeLocationX = {var.probeLocationX}
                set global.probeLocationY = {var.probeLocationY}
                set global.probeLocationZ = {var.probeLocationZ}
            elif exists(global.probeLocationX) == false
                ;else define the probe location
                global probeLocationX = {var.probeLocationX}
                global probeLocationY = {var.probeLocationY}
                global probeLocationZ = {var.probeLocationZ}
            vs
            ;clear variables
            unset global.probeLocationX
            unset global.probeLocationY
            unset global.probeLocationZ
            ;redefine varaibles
             global probeLocationX = XX.XX
             global probeLocationY = YY.YY
             global probeLocationZ = ZZ.ZZ
            Yeah its less code, but im not convinced its less work.
            Im not saying it a bad idea, its just not getting my upvote for the reasons above and I think there are more pressing features to develop, but if this low hanging fruit for devs, then why not.
            It would be better that the "global <var> = <expression>" command just did double duty and defined or redefined the global variable.
            undefined 1 Reply Last reply 25 Aug 2021, 22:11 Reply Quote 0
            • undefined
              fcwilt @egmrudd
              @egmrudd
              well unset globals would do all globals - you wouldn't need to do them one at a time.
              undefined 1 Reply Last reply 28 Dec 2021, 23:15 Reply Quote 1
              • undefined
                oliof @fcwilt
                @dc42 any chance for this? I am getting an explosion of statements due to the checking constructs that @egmrudd proposed; ten variable assignments are now 40 lines of code. And I haven't even started with interesting things yet (-:
                undefined 1 Reply Last reply 29 Dec 2021, 09:34 Reply Quote 0
                • undefined
                  dc42 administrators @oliof
                  @oliof I am considering allowing the "global" command to be used even if there is an existing global variable with the same name. It would replace the original value. This disadvantage would be that of you accidentally used the same global variable name for different purposes in more than one script, it could become difficult to work out what the problem was.
                  undefined undefined 2 Replies Last reply 29 Dec 2021, 10:26 Reply Quote 0
                  • undefined
                    oliof @dc42
                    @dc42 maybe enable that with a "I know that I am shooting myself in the foot" G-Code?
                    undefined 1 Reply Last reply 1 Jan 2022, 20:30 Reply Quote 0
                    • undefined
                      Stephen6309 @oliof
                      @oliof Wouldn't that be an ID10T error?
                      • undefined
                        oliof
                        you can call it whatever you want but dc42 being a veteran c++ developer probably is well versed with the footgun analogy
                        undefined 1 Reply Last reply 19 Jun 2022, 23:17 Reply Quote 0
                        • undefined
                          tfjield @oliof
                          This is an old thread, but I've just run into this issue and I wanted to share my workaround. I wanted to be able to keep my data neat and not have to have the same value on more than one line. (Because that provides an opportunity for errors, especially later when I'm changing something.)
                          I thought of creating a script file to do it, but I couldn't figure out how to reference the contents of the parameters directly, so I wrote them to a file.
                          I have all my globals in a file such as the following, and I set them using the "setglobal.g" script.
                          ; globals.g
                          ; called to initialize all global variables
                          M98 P"setglobal.g" L"leveled" V"false"		; flag indicating whether the bed has been leveled
                          M98 P"setglobal.g" L"xmin" V0			; x-axis minimum limit
                          M98 P"setglobal.g" L"xmax" V620			; x-axis maximum limit
                          M98 P"setglobal.g" L"ymin" V-28			; y-axis minimum limit
                          M98 P"setglobal.g" L"ymax" V600			; y-axis maximum limit
                          M98 P"setglobal.g" L"xprobeoffset" V5		; x-axis offset for probing z-axis datum
                          M98 P"setglobal.g" L"yprobeoffset" V5		; y-axis offset for probing z-axis datum
                          ;etc.
                          The "setglobal.g" file writes the logic to check if the variable exists or not, and then executes it:
                          ; setgobal.g
                          ; Creates a global variable (if it doesn't already exist) and sets it to a value
                          echo >"tempglobal.g" {"if !exists(global."^param.L^")"}
                          echo >>"tempglobal.g" "    global "^param.L^" = "^param.V
                          echo >>"tempglobal.g" "else"
                          echo >>"tempglobal.g" "    set global."^param.L^" = "^param.V
                          M98 P"tempglobal.g"
                          Seems to work alright, and keeps my code fairly neat. There are probably limitations to this approach, but I don't know what they are, yet. lol
                          undefined 1 Reply Last reply 19 Jun 2022, 23:23 Reply Quote 0
                          • undefined
                            fcwilt @tfjield
                            @tfjield
                            Interesting but why?
                            If you create all your global variables at print boot-up then you know they will succeed in being created.
                            undefined 1 Reply Last reply 19 Jun 2022, 23:33 Reply Quote 0
                            • undefined
                              tfjield @fcwilt
                              @fcwilt Because not all variable changes are used in config.g. Some of the variables are used elsewhere, and for development I would like to update them without having to rerun config.g. And yes, I could change the value and update the globals.g file, but that's tedious. It's just so simple to rerun globals.g after I've made my changes and go on with testing. Of course, if the variables are used in config.g then I have to run it.
                              Also, this gives me the flexibility of defining a global in another file and not in globals.g, and I don't have to check whether or not it already exists.
                              Like most things, once everything is set up and working right, then it doesn't matter how you got there, how many lines of code, etc. But for development and iteration, I'm finding this helps.
                              undefined 1 Reply Last reply 19 Jun 2022, 23:41 Reply Quote 0
                              • undefined
                                fcwilt @tfjield
                                @tfjield
                                Thanks for the explanation.
                                undefined 1 Reply Last reply 19 Jun 2022, 23:47 Reply Quote 0
                                • undefined
                                  tfjield @dc42
                                  @dc42 How about automatically creating the global if it doesn't already exist when set it called, and allowing global to set an already existing variable? I'm thinking that would maintain backwards compatibility while going forward it would allow simplifying the scripts. I actually like variable declarations in code with strongly-typed languages, but not so much in scripting.
                                  undefined 1 Reply Last reply 19 Jun 2022, 23:54 Reply Quote 0
                                  • undefined
                                    tfjield @fcwilt
                                    @fcwilt For sure! 👍
                                    • undefined
                                      fcwilt @tfjield
                                      @tfjield said in G-Code Meta commands: Option unset (all) globals:
                                      I want you to think long and hard about what you are proposing. 😉
                                      I am prepared to forgot you ever suggested such a thing.
                                      undefined 1 Reply Last reply 20 Jun 2022, 00:23 Reply Quote 0
                                      • undefined
                                        tfjield @fcwilt
                                        @fcwilt 🤣
