    Nozzle skipping across part
    • kb58
      kb58 last edited by
      I realize that this isn't related to Duet products, but there is so much knowledge here, I'm guessing someone will know how/why this is happening. In the pic below, the nozzle left a pale scratch mark as it moved away from the left edge at an approximate +45 degree angle. It's almost as if the move is happening at a nozzle height of 0.000mm. The question is: why.
      If the nozzle-to-bed offset was wrong, since Z movements are relative... I think, it wouldn't matter in that respect. Vertical wall quality appears fine, so it seems like the Z bed is moving correctly.
      It could be the slicer (PrusaSlicer) not stepping the Z axis sufficiently before the move started. That's hard to believe since it's so widely used; I'd expect complaints would be very vocal if that were the case.
      It could be that the PLA+ material expands after it's laid down, which does not make much sense.
      Any ideas?
      Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @kb58 last edited by
        @kb58
        That's likely just the slicer doing a move from one place to the next.
        There may be a setting that will raise the nozzle a bit before such moves.
        There may be an "ironing" feature which is used on the top layers to try and smooth the surface.
        But I have never tried either feature.
          It looks like you have a bit of over extrusion as well. The little ridges between extrusion paths is the give away. If you reduce the flow rate ~5% that might get rid of the ridges and also solve the nozzle marks on the top layer without having to resort to Z hop.
          kb58 1 Reply Last reply Reply Quote 1
          • kb58
            kb58 @Phaedrux last edited by
            @phaedrux Okay, thanks, I'll experiment with that. I'm so new to 3D printers that I have little experience to lean on as for what "best" or "acceptable" is.
              Phaedrux Moderator @kb58 last edited by
              @kb58 If you haven't seen or used this guide on basic calibration yet it's a good starting point. A level bed and proper flow rate is the foundation of a good print.
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
