    Duet 2 WiFi problem with the T-D500 thermistor
    Firmware installation
    • pampundefined
      pamp
      Hello
      I set this code for the T-D500 thermistor:
      M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 C5.548428e-8 R4700 H0 L0
      M950 H1 C"e0heat" T1
      M307 H1 B0 S1.00
      M143 H1 S350
      and incorrectly shows room temperature, instead of 24C it shows 11-13C. At 95C the board shows 91C.
      How to calculate the correct parameters for this thermistor from this table?
        jay_s_uk @pamp
        @pamp those thermistors are know to be poor as temperatures below 100 degrees due to their very high resistance. Not much you can do
        pampundefined 1 Reply Last reply Reply Quote 0
        • pampundefined
          pamp @jay_s_uk
          @jay_s_uk so not to worry about it?
            jay_s_uk @pamp
            @pamp yep, don't worry about it
            • Gixxerfastundefined Gixxerfast referenced this topic
