    Stall detection buggy/inconsistent
    STM
    • semi55undefined
      semi55
      Hi guys,
      I have some really inconsistent results with stall detection. Sensorless homing works fine, as well as recognizing a stall during printing. The problem lies in the rehome procedure.
      FYI: I have a BLtouch on my Y-Axis (Belt printer). I use sensorless homing on the X-axis during the rehoming procedure and the BLtouch for homing the Y-axis. I run on SBC mode controlling an STM based board with multiple configurations. The rehome files is located in the sys folder of the active configuration
      This is my rehome.g file:
      ; home X
      M280 P0 S160				; reset Bltouch for robustness
      M402						; retract probe for safety reasons
      G91               			                ; relative positioning
      G1 H2 Y-5 X5 F10000   		; lift y relative to current position
      G1 H2 X10 Y10 F18000   		; move X relative to current position
      ;Stall detection section
      M574 Y1 S3					; Enable sensorless homing on Y axis
      M574 X1 S3					; Enable sensorless homing on X axis
      M915 P0 S30 H150 R0			; Stall sensitivity Y axis
      M915 P3 S30 H150 R0			; Stall sensitivity X axis
      M913 X70 Y70				; Lower motor current
      G4 P200						; delay to ensure settings are made
      M400						; Wait for commands to finish
      G1 H1 X-245 F2400 			; move quickly to X axis endstop and stop there (first pass)
      G1 H1 X-245 F2000  			; move slowly to X axis endstop once more (second pass)
      G1 X10						; move X
      M913 X100 Y100				; reset motor currents
      M574 Y1 S2					; Enable Z-probe again
      ; home Y
      G1 H2 Y-15 X15 F10000   	        ; lift y relative to current position
      M401 						; deploy probe
      G1 H1 Y-285 F2000 			; move Y down until BLTouch is triggered
      G92 Y1.8					; set Bltouch offset
      G1 Y5						; move Y up
      M574 Y1 S3					; Enable sensorless homing on Y axis again
      M24 						; resume print
      M915 X Y S28 R3 F1 H200
      This script succeeds roughly 20% of the time. Most of the time at some point of this script, the printer just stops and does nothing. It can't resume the print when this is happening.
        Phaedrux Moderator @semi55
        @semi55 said in Stall detection buggy/inconsistent:
        When it stops are you able to grab the results of sending M122?
        semi55undefined 1 Reply Last reply Reply Quote 0
        • semi55undefined
          semi55 @Phaedrux
          @phaedrux I've tried to send M122 through the DWC when it stops but unfortunately I got no output.
          I've hooked up Pronterface directly to the STM board next and also got nothing until I've rebooted the firmware through theDWC:
          >>>M122
          SENDING:M122
          //after reboot://
          Done printing file
          Cancelled printing file 0:/gcodes/stallV2.gcode, print time was 0h 0m
          Printing resumed
          RepRapFirmware for STM32F4 based Boards (biquskrpro_1.1) version 3.3_2 (2021-06-19 17:12:49) running on STM32F4 (SBC mode)
          Used output buffers: 4 of 40 (16 max)
          Static ram: 18112
          Dynamic ram: 63788 of which 24 recycled
          Never used RAM 48120, free system stack 117 words
          Tasks: SBC(ready,6.8%,316) HEAT(suspended,0.0%,343) MAIN(running,93.1%,428) IDLE(ready,0.0%,30), total 100.0%
          Owned mutexes: USB(MAIN)
          Last reset 00:02:03 ago, cause: [software]
          Last software reset at 2021-07-27 08:59, reason: User, none spinning, available RAM 48360, slot 0
          Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
          Error status: 0x00
          [ERROR] Error status: 0x00
          Step timer max interval 0
          MCU temperature: min 57.5, current 58.3, max 58.3
          Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/96/64, gc cycles 0
          Driver 0: position 1295, 2209 standstill, reads 6627, writes 6, SG min/max 12/450
          Driver 1: position 311, no-driver-detected
          Driver 2: position 386, 2209 standstill, reads 6633, writes 0, SG min/max 8/8
          Driver 3: position 0, 2209 standstill, reads 6626, writes 6, SG min/max 70/460
          Driver 4: position 0, no-driver-detected
          Driver 5: position 0, 2209 standstill, reads 6632, writes 0, SG min/max 0/2
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Date/time: 2021-07-27 09:01:35
          Slowest loop: 78.40ms; fastest: 0.03ms
          === DDARing ===
          Scheduled moves 39, completed moves 39, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          Bed heaters = 1, chamberHeaters = 2
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File* is idle in state(s) 0
          USB is ready with "M122" in state(s) 0
          Aux is idle in state(s) 0
          Queue* is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0 0, running macro
          Aux2 is idle in state(s) 0
            jay_s_uk @semi55
            @semi55 can you upgrade to 3.3.0_5?
            It also looks as though 2 of your driver's aren't in UART mode.
            Can you post an output of M122 P200
            • semi55undefined
              semi55 @jay_s_uk
              @jay_s_uk I've upgraded the board to 3.3.0_5 and the SBC to the latest 3.3.0 stable release but unfortunately with no effect. It still stops randomly sometimes.
              I've tried to cancel the print after it stopped and got this:
              M0 H1
              Error: M0: Pause the print before attempting to cancel it
              which seems odd as the print should be paused, or is it maybe because it is getting stuck in the script somewhere?
              Driver 1 and and 4 are not in use btw. I have a weird arrangement due to one driver slot being fried.
              This is the output of M122 P200:
              M122 P200.txt
