BLtouch and Railcore 300ZL problems
@obiwan2print said in BLtouch and Railcore 300ZL problems:
@fcwilt When I use the G28 Z command the nozzle goes to the back right corner and stops with the BLtouch located off the print platform. I would like to move the nozzle in the negative Y direction in order to have the BLtouch on the print platform. Any suggestion on how accomplish this task? I tried changing the G31 Y offset value in the config.g but it still homes to the back location when using G28 Z.
The position it goes to is defined in homez.g. If it's not going where you want it, you need to edit that file.
undefined ObiWan2Print referenced this topic
