resurrect.g file does not finish correctly
today i tried to configure M911 " Configure auto save on loss of power".
It worked only until a certain point of the procedure.
1.print started
2.hit emergency button
4.start printer
3.typed M916 into console
4.procedure begins
5.resurrect.g also is created and resurrect-prologue.g within the resurrect.g is also executed
6.Stops after heating to preious temp and getting the right tool
7.print doesn't resumeHere my code:
line in Config.g
M911 S21.9 R23.0 P"M913 X0 Y0 G91 M83 G1 E-3 Z3 F800" ; Autosave at Powerfailure
resurrect.g
; File "0:/gcodes/mng.gcode" resume print after print paused at 2021-07-28 16:36 G21 M140 P0 S80.0 G29 S1 T-1 P0 G92 X191.590 Y158.915 Z-13.630 G60 S1 G10 P0 S0 R0 G10 P2 S0 R0 G10 P3 S0 R0 G10 P1 S200 R200 T1 P0 M98 P"resurrect-prologue.g" M116 M290 X0.000 Y0.000 Z0.000 R0 T-1 P0 T1 P6 ; Workplace coordinates G10 L2 P1 X0.00 Y0.00 Z0.00 G10 L2 P2 X65.00 Y134.00 Z0.00 G10 L2 P3 X152.00 Y160.00 Z0.00 G10 L2 P4 X237.00 Y185.00 Z0.00 G10 L2 P5 X0.00 Y0.00 Z0.00 G10 L2 P6 X0.00 Y0.00 Z0.00 G10 L2 P7 X0.00 Y0.00 Z0.00 G10 L2 P8 X0.00 Y0.00 Z0.00 G10 L2 P9 X0.00 Y0.00 Z0.00 G54 M106 S0.00 M106 P0 S0.00 M116 G92 E0.00000 M83 M486 S0 A"Process1" M486 S0G17 M23 "0:/gcodes/mng.gcode" M26 S18283 G0 F6000 Z2.150 G0 F6000 X191.590 Y158.915 G0 F6000 Z0.150 G1 F2100.0 P0 G21 M24 the procedure stop at least at line 17 in resurrect.g.
So by the way what exactly does "T1 P6" mean? Couldn't figure it out. Maybe to set the coordinate system P6 below?Is there a special order dependency for M911 in config.g?
I'm using:
Duet2Ethernet + Duex Expansionboard 5 channel
RRF 3.3 -
https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure#main
I'm not sure if hitting the emergency stop is going to function in the same way as a power loss.
T1 P6 means select tool 1 and apply offsets.
https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_T_Select_Tool
Can you post your full config.g?
@phaedrux thank you for the quick response.
config.g
Configure auto save on loss of power at line 81; config.g ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"" ; set printer name M575 P1 S1 B57600 ; set serial comms parameters M667 S1 ; select CoreXY mode ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes forwards M569 P4 S0 ; physical drive 4 goes forwards M569 P5 S0 ; physical drive 5 goes forwards M569 P6 S1 ; physical drive 6 goes forwards M584 X0 Y1 Z2 E3:4:5:6 ; set drive mapping M350 X16 Y16 Z16 E16:16:8:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z640 E837.00:4214.00:1240:4214.00 M566 X900.00 Y900.00 Z100.00 E120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X30000.00 Y30000.00 Z2000.00 E1200.00:1000.00:1200.00:1200.00 ; set maximum speeds (mm/min) M201 X800.00 Y800.00 Z1200.00 E2500.00:1000.00:250.00:2500.00 ; set accelerations (mm/s^2) M906 X1800 Y1800 Z1800 E1400:1400:1400:1400 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-17 Y0 Z3 S1 ; set axis minima M208 X415 Y255 Z408 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for high end on Z only for BL-Touch ; Z-Probe M558 P9 C"^zprobe.in" H10 F900 T20000 A1 R0.75 S0.02 B0 X0 Y0 Z1 ; set Z probe type to bltouch and the dive height + speeds M950 S1 C"duex.pwm4" ; create servo pin 0 for BLTouch on exp.heater6 --> duex.pwm4 G31 P500 X25.4 Y-39.3 Z4 ; set Z probe trigger value, offset and trigger height -1.005 M557 X10:410 Y0:215 P12 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" Q100 T0 ; create bed heater output on bedheat and map it to sensor 0 M570 H0 P10 T20 S60 ; configer heaterfault detection M140 H0 M143 H0 S220 ; set temperature limit for heater 0 to 200C M307 H0 R1.086 C347.9 D2.11 S1.00 V23.9 M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1 M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M570 H1 P10 T20 S60 ; configer heaterfault detection M143 H1 S510 ; set temperature limit for heater 1 to 500C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q5 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Tools M563 P0 S"Heatbed" D0 H5 F0 ; define tool 0 M563 P0 S"Tool_0" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z-5.33 ; Set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Miscellaneous M950 S0 C"duex.pwm5" ; create servo pin 0 for Magnet on exp.heater7 --> duex.pwm5 M950 J1 C"e1stop" ; Configure Pin number1 to e1stop M581 P1 T2 S0 R1 M911 S21.9 R23.0 P"M913 X0 Y0 G91 M83 G1 E-3 Z3 F800" ; Autosave at Powerfailure M376 H5 ; Set bed compensation taper ; set tools in standbay mode after start up T0 P0 ; call tool 0 without any movements G4 P500 ; wait 500 ms T-1 P0 ; remove any tool without any movements ; set tool change positions in X and Y global tool0_posX = -16.3 ; Set toolposition X for Tool 0 global tool0_posY = 315.9 ; Set toolposition Y for Tool 0 M98 P"Actual Toolnumber.html" ; call and set actual Toolnumber form file sys/Actual Toolnuber M501 ; Restore parameter from config-override.g My emergency stop cut of the power from the duet board directly so it simulates like an conventional power outage/blackout. I configured it a while ago and it worked out with the emergency stop. Since the last time i tested it, i had a few RFF updates, so maybe there could be an issue.
How many tools do you actually have? It seems like you only have 1 tool configured, but you also have T-1 P0 in there. And you have 4 extruder motors defined.
What is this? M98 P"Actual Toolnumber.html"
