    Can´t update duet3 via SBC :/
    Firmware installation
    543
    • duttiundefined
      dutti
      hey.
      I just installed the new rasperry pi 4 and I can´t update the firmware of the duet3 and the expansion board.
      Please I need a little help.... thanks a lot!
      I lost all my files also...
      duttiundefined 1 Reply Last reply Reply Quote 0
      • duttiundefined
        dutti @dutti
        I tried to do this: 950e870b-253b-48b9-80a4-007565c57043-image.png
        • duttiundefined
          dutti @dutti
          @barbarossa-cologne
          also update via SBC is not possible... any ideas? 😕
          thanks a lot
            Have you seen this?
            https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3
            It looks like your Duet is running RRF 3.0, but I can't tell what your Pi is running. Did you use the provided Duet Pi image?
            If the Duet is on a much older firmware version you may need to update it using USB and Bossa to the latest version 3.3 so that it can start talking to the Pi again.
            @barbarossa-cologne said in Can´t update duet3 via SBC 😕:
            The Duet Pi install has it's own configuration folder on the Pi itself. You will need to copy your configuration from the SD card in the Duet and upload it to DWC afterwards. The SD card in the Duet must be removed to use the Pi.
            • duttiundefined
              dutti @Phaedrux
              @phaedrux
              So now I´ve connected the pi correctly...
              also:
              updating raspberry
              updating duet 3 via sbc
              found old g-code.
              But the console says I need an upgrade of the firmware.
              duet3
              Send code...
              Status
              Starting
              Mode: FFF
              No Status
               Tools
               Extra
               Control Heaters
              No Tools
              Temperature Chart
              No Data
              System Directory
              0:/sys/config.g
              ; Default config.g template for DuetPi
              ; Replace this with a proper configuration file (e.g from https://configtool.reprapfirmware.org)
              ; Display initial welcome message
              M291 P"Please go to <a href=""https://www.duet3d.com/StartHere"" target=""_blank"">this</a> page for further instructions on how to set it up." R"Welcome to your new Duet 3!" S1 T0
              ; Enable network
              M552 P0.0.0.0 S1
              Duet 3
              Send code...
              Status
              Printing
              Mode: FFF
              Tool Position
              X
              321.1
              Y
              339.5
              Z
              24.14
              Extruder Drives
              Drive 0
              14981.4
              Drive 1
              14979.7
              Drive 2
              0.0
              Speeds
              Requested Speed
              75 mm/s
              Top Speed
              75 mm/s
              Sensors
              Vin
              23.9 V
              V12
              12.1 V
              MCU Temperature
              43.2 C
              Z-Probe
              0
               Tools
               Extra
               Control All
              Tool	Heater	Current	Active	Standby
              Tool 0
              T0	Heater 1
              active	209.9 C
              210
              215
              Bed	Heater 0
              active	49.8 C
              50
              0
              Temperature Chart
              System Directory
              0:/sys/config.g
              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit)
              M550 P"Duet 3" ; set printer name
              M569 P0.1 S1 ; physical drive 0.1 goes forwards
              M569 P0.2 S1 ; physical drive 0.2 goes forwards
              M569 P0.3 S1 ; physical drive 0.3 goes forwards
              M569 P0.4 S1 ; physical drive 0.4 goes forwards
              M569 P0.5 S1 ; physical drive 0.5 goes forwards
              M569 P1.0 S1 ; physical drive 1.0 goes forwards
              M569 P1.1 S1 ; physical drive 1.1 goes forwards
              M569 P1.2 S1 ; physical drive 1.2 goes forwards
              M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
              M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
              M92 X160.00 Y160.00 Z1600.00 E409:409:409 ; set steps per mm ; set steps per mm
              M566 X900.00 Y900.00 Z260.00 E50.00:50.00:50.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X12000.00 Y12000.00 Z240.00 E50000.00:50000.00:50000.00 ; set maximum speeds (mm/min)
              M201 X2000.00 Y2000.00 Z1860.00 E4050.00:4050.00:4050.00 ; set accelerations (mm/s^2)
              M906 X1400 Y1400 Z3000 E1000:1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X700 Y700 Z800 S0 ; set axis maxima
              M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
              M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in
              M558 P9 C"io4.in" H10 F200 T2500 ; set Z probe type to bltouch and the dive height + speeds
              M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
              G31 P25 X0 Y-36 Z2.5 ; set Z probe trigger value, offset and trigger height
              M557 X10:600 Y10:600 S200 ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
              M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
              M143 H0 S90 ; set temperature limit for heater 0 to 90C
              M308 S1 P"temp1" Y"thermistor" T100000 B4138                                     ; configure sensor 1 as thermistor on pin temp1
              M950 H1 C"out1" T1                                                               ; create nozzle heater output on out1 and map it to sensor 1
              M307 H1 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
              M950 F0 C"out8" Q500 ; create fan 0 on pin out3 and set its frequency
              M106 P0 S0.5 H-1  ; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
              M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
              M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
              M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on
              ; Dual extruder motor
              M572 D0:1 S0.05:0.05
              M563 P0 D0:1 H1 F0 ; define tool 0
              M567 P0 E1.00:1.00 ;set mixing ratio
              M671 X185:185:615:615 Y-125:925:925:-125 S2.5
              M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power
              • duttiundefined
                dutti @dutti
                • duttiundefined
                  dutti @dutti
                  @barbarossa-cologne
                  I decided to make a complete new configuration.
                  So maybe I just need help If this doesn´t work.
                    The firmware on your Duet is still only 3.0.
                    You can try uploading these two zip files one at a time and see if it will update.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                    Otherwise, you'll need to use USB and Bossa to flash it directly to 3.3
                    https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_2
                    duttiundefined 3 Replies Last reply Reply Quote 0
                    • duttiundefined
                      dutti @Phaedrux
                      @phaedrux
                      ok I´ll try to upload it at the same time...
                      I decided to make a complete new configuration via the config tool. Do I have to use bossa also then?
                      thanks for the help -- I´m building two tool changer with max build volume of 1m3. Without your help it wouldn´t ne possible!!!
                      • duttiundefined
                        dutti @Phaedrux
                        @phaedrux is at normal that I can reach the DWC with two different IP-adressses ? (192.168.2.105 192.168.2.104 in this case.?
                        • duttiundefined
                          dutti @Phaedrux
                          This post is deleted!
                            Phaedrux Moderator @dutti
                            Possibly if your Pi has ethernet and wifi connected at the same time...
                            • duttiundefined
                              dutti @Phaedrux
                              @phaedrux just connected wifi ones....
                              So I definetly I have to renew the firmware via bossa`?
                              that´s the 3rd time..... everytime different mainboards.
                              thanks
                                Well if you have a separate SD card you could set that up with the /sys and /www folders with DWC files in it, and you could put that in the Duet itself without the Pi and run the Duet in standalone mode. Once you have DWC up you can upload those zip files one at a time and it should update you to 3.3. Then reconnect the Pi.
                                You could also runa. USB cable between the Pi and Duet and use the Pi to flash with bossac.
                                • duttiundefined
                                  dutti @Phaedrux
                                  @phaedrux
                                  Thanks for all the support.
                                  But don't care what I do... nothing worked. There is everywhere a step which stops the hole procedure. Now, I can't connect to the Duet anymore.
                                  See different post - now changing the board..
                                  Thanks to you!
