Trouble with micro servos.
I'm trying to run a micro servo from a PWM connection on my Duex 5, but I don't seem to be able to get it to move at all with what I think are the correct settings. I can get some movement if I change the PWM frequency to much higher than it should be, but it never moves to where I think it should.
The servo is an MG90S. I have tried swapping it (I bought a pack of 3), but no change. It is connected to PWM_5 on my Duex.
I'm running:
- Duet 2 WiFi with Duex 5
- RRF 3.3
I have separate 5V power connected to the Duex's 5V Aux In and the jumper changed to select this.
According to the internet, the servo expects a 50Hz PWN frequency, and a 1ms pulse should put it to the minimum position, a 1.5 ms pulse should put it to the middle and a 2ms pulse should put it to the maximum position.
I think I should configure the servo with:
M950 S0 C"!duex.pwm5" Q50
and then set its position with, ie:
M280 P0 S1000 M280 P0 S1500 M280 P0 S2000
for the positions mentioned above.
This does nothing, except turn on the LED next to the heater 7 output (I have nothing connected to any of the duex heaters).
If I instead do:
M950 S0 C"!duex.pwm5" Q500
then the position commands do cause movement, just very small amounts, definitely not going to the correct positions.
Different values of Q give different results, 250 gives some big movements, but I'm fairly sure I shouldn't be changing that number at all.
Please help me, I have no idea what I'm doing.
@ernst-blofeld
AFAIK, for servos you don't set any Q-value.
Make sure you have sufficient current to move the servo (external 5V perhaps) -
@ernst-blofeld use:
M950 S0 C"duex.pwm5"
Don't invert the pin, and there is no need to specify the frequency.
@dc42 said in Trouble with micro servos.:
@ernst-blofeld use:
Thanks Dave, my servo is now moving, but only 90 degrees between min and max, where I expected 180 degrees. Any ideas on that?
@ernst-blofeld what commands are you sending to move it to the ends of its range?
M280 P0 S1000
to send to minimumand
M280 P0 S2000
to send to maximumExperimentally, I can get 180 degrees by using S600 for min and S2400 for max. I don't know what that means. Values below 600 seem to cause it to spin round to the other extreme and values over 2400 seem to be ignored.
The docs for M280:
From the docs for M280:
S values below 544 are treated as angles, and 544 or greater as the pulse width in microseconds.
@fcwilt said in Trouble with micro servos.:
The docs for M280:
Yes! I'd become fixated on using the pulse width. S0 through S180 seem to work as expected.
