    Extruder E1 not working
    735
    • jackd2282undefined
      jackd2282 @Phaedrux
      @phaedrux it was physically burned and not dremeled out
      jackd2282undefined 1 Reply Last reply Reply Quote 0
        jackd2282 @jackd2282
        @jackd2282 I don’t know why driver 4 would be affected though. It wasn’t even hooked up when this happened but back to my question on the expansion boards, would that bypass this problem?
          Well yes, if you added an expansion board like a Duex or external driver expansion board you could use the drivers on that as replacements. Just map the extruders to the new drivers with M584.
          @jackd2282 said in Extruder E1 not working:
          I'm not sure, but I think if the damage was bad enough it may have damaged the SPI bus which could cut communication to further drivers down the line.
            jackd2282 @Phaedrux
            @phaedrux that would make sense why my xyz still work
            jackd2282undefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
              @jackd2282 ordered the expansion board so will see when it comes in
                @jackd2282 ok so I am thinking that the expansion board may not work. It’s not here yet but I was taking for granted that my other drivers worked because they did before all this. But that’s not the case. None of them do. Same problem phase a and b. I tried just the z and modified the config.g to only include that drive and nothing. My board may be shot and that sucks cause I just bought that expansion board with next day shipping for nothing. None of them get warm. No errors unless I try to move a motor. I tried resetting the firmware on the board and card to just start over but no luck.
                  Phaedrux Moderator @jackd2282
                  Did they work before but not anymore?
                    jackd2282 @Phaedrux
                    @phaedrux they worked before the extruder problem but I was so focused on that that I didn’t even try them.
