    Need help, Bondtech with Duet 3 mini 5
    • davidewenundefined
      davidewen
      I have a Bondtech DDX v3 and a Mini 5+.
      I'm not able to get my extrusion settings correct.
      Initially configured via RRF tool.
      Microstepping = x16(on)
      Steps per mm = 436.54
      Max speed change = 2
      Max speed mm/s = 20
      Acceleration mm/s = 250
      Motor Current = 800mA
      config.g
      NOTE: the extra info is test parameters
      M569 P0.0 S0 ; physical drive 0.0 goes backwards
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M350 E256 I0 ; configure microstepping without interpolation
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      ;M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      ;M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      ;M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      ;M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
      ;M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M92 X80.00 Y80.00 Z400.00 E436.54 ; set steps per mm
      ;M92 X53.33 Y53.33 Z2560.00 E48.5 ; set steps per mm
      M203 X18000.00 Y18000.00 Z300.00 E12000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z10.00 E100.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E720 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      Th0mpyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • Th0mpyundefined
        Th0mpy @davidewen
        @davidewen What kind of issue are you having?
        Usually the team that scores the most points wins the game.
        davidewenundefined 1 Reply Last reply Reply Quote 0
          davidewen @Th0mpy
          @th0mpy
          Great question. I guess I only partially explained it.
          Extrusion lengths are not correct when using the web interface.
          When I have 100mm extrusion length selected, I only get about 10mm of extrusion.
            Phaedrux Moderator @davidewen
            @davidewen said in Need help, Bondtech with Duet 3 mini 5:
            Just use x16 microstepping with interpolation enabled. Set your steps per mm to suit. Then try calibrating the extruder again.
              davidewen @Phaedrux
              @phaedrux
              Thanks.
              I've adjusted the interpolation.
              Is there a guide showing how to calibrate the extruder?
                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                  davidewen @Phaedrux
                  @phaedrux
                  Thanks.
                  That did the trick.
