    Job working from DWC but faulty when called from config.g
    Using Duet Controllers
    70
    • Yurk_12
      Yurk_12 last edited by
      My gcode job describes a certain motion to drive 5 Nema 8 motors. The job is in the Jobs folder and it is run on startup thanks to a M32 filename.gcode added to config.g.
      The following happened: during the job, 2 motors were mechanically stopped for about 30 min. The job was still executing. I turned off the board, fixed the mechanical part, and started again the board: the job is run but commands with low speed are not executed while commands with high speed are executed.
      When I run the job by uploading it in DWC and starting it from DWC it still works as expected. It seems that calling the job from config.g or calling the job from DWC is different.
      The job looks like below.
      Lines #1,#2 are properly executed.
      In line #3, only the X-200 is executed. The Y,Z,U,V-5.4 are not executed, and this only when the job is called from the config.g at startup. Diagnostics pasted below.
      Any idea what is happening? In general also, how bad is it if a job is mechanically blocked for a long time with mechanically stopped motors?
      Thanks a lot
      G21 G91
      G1 X-200.0 Y-145.94594594594594 Z-91.89189189189189 U-37.83783783783784 F18500
      G1 X-200.0 Y-5.405405 Z-5.405405 U-5.405405 F9250.0
      G1 X-5.405405 Y-5.405405 Z-5.405405 U-5.405405 F500.0
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus Ethernet (standalone mode)
      Board ID: 5DNBA-B296U-D65J0-40KM6-2503Z-HSDTT
      Used output buffers: 3 of 40 (13 max)
      Static ram: 102724
      Dynamic ram: 99352 of which 296 recycled
      Never used RAM 41332, free system stack 152 words
      Tasks: NETWORK(ready,27.7%,240) ETHERNET(notifyWait,0.1%,574) HEAT(delaying,0.0%,415) Move(notifyWait,0.1%,300) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,0.7%,115) MAIN(running,70.2%,408) IDLE(ready,0.4%,29) AIN(delaying,0.8%,264), total 100.0%
      Owned mutexes:
      Last reset 00:02:19 ago, cause: power up
      Last software reset at 2021-08-04 21:08, reason: User, GCodes spinning, available RAM 41332, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      MCU revision 3, ADC conversions started 139750, completed 139748, timed out 0, errs 0
      Step timer max interval 797
      MCU temperature: min 24.6, current 31.0, max 31.0
      Supply voltage: min 10.5, current 11.0, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position -203676, standstill, SG min/max 0/24, read errors 0, write errors 0, ifcnt 16, reads 7313, writes 16, timeouts 0, DMA errors 0
      Driver 1: position -97297, standstill, SG min/max 0/102, read errors 0, write errors 0, ifcnt 16, reads 7313, writes 16, timeouts 0, DMA errors 0
      Driver 2: position -84324, standstill, SG min/max 0/34, read errors 0, write errors 0, ifcnt 16, reads 7312, writes 16, timeouts 0, DMA errors 0
      Driver 3: position -24649, standstill, SG min/max 0/88, read errors 0, write errors 0, ifcnt 16, reads 7312, writes 16, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 7320, writes 9, timeouts 0, DMA errors 0
      Driver 5: position 0, assumed not present
      Driver 6: position 0, assumed not present
      Date/time: 2021-08-04 21:16:47
      Cache data hit count 230021930
      Slowest loop: 210.47ms; fastest: 0.11ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.7ms, write time 2.1ms, max retries 0
      DMs created 83, maxWait 19454ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 7, completed moves 7, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters = -1 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 699, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 699/0/0
      Tx timeouts 0,0,698,0,0,0 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 1054.23ms; fastest: 0.03ms
      HTTP sessions: 1 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      Socket states: 5 2 2 2 2 0 0 0
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @Yurk_12 last edited by
        @yurk_12
        Doing anything like that from config.g seems like a very bad idea to me.
        Why are you trying to do that?
          What was the mechanical issue? Are you sure it's not still a mechanical issue? Like a loose grub screw maybe? Those are small motors, did they get burnt being locked in position while trying to move?
          @fcwilt said in Job working from DWC but faulty when called from config.g:
          For a printer that has pinch points, certainly, but I get the sense this maybe isn't a typical usage of a Duet.
          Yurk_12 1 Reply Last reply Reply Quote 1
          • Yurk_12
            Yurk_12 @Phaedrux last edited by
            Thanks @fcwilt and @phaedrux.
            It is not a 3D printer. I am actuating motors to achieve a certain function in a mechanical assembly.
            For a very easy user experience. The user starts the power of the assembly and the desired motion is executed.
            2 motors were mechanically stuck into one position. No rotation possible during the 30 min of blocking.
            I am sure the mechanical issue has been fixed. The job now works normally when called from DWC. I'm switching back and forth between calling the job from DWC and from config.g and it alternately works and fails.
            Maybe, but everything works as expected when calling the job from DWC.
            Job called from DWC: success
            Job called from config.g and ethernet cable connected to computer: fail
            Job called from config.g and no cable plugged: fail
            fcwilt Phaedrux 2 Replies Last reply Reply Quote 0
            • fcwilt
              @yurk_12
              Thanks for the info.
              It didn't sound like you were talking about a printer.
              Just the same the idea of having mechanical motion on power up doesn't seem like a good idea.
              A short power outage will lead to possibly unexpected activity.
              Hope you get things sorted.
              Good luck.
                Phaedrux Moderator @Yurk_12 last edited by
                @yurk_12 said in Job working from DWC but faulty when called from config.g:
                Can you try adding a delay in your config.g of a few seconds with G4 S4 right before your job is called and move the job call to the end of the file and see if it makes a difference.
                Could you share your config.g?
                • Yurk_12
                  Thanks @fcwilt.
                  I see your point, but I'd argue that systems that start upon powering up are ubiquitous (a simple room fan starts blowing whenever you turn it on).
                  Thanks @phaedrux.
                  Ah yes, good point. A main difference between running from config and from DWC is the time the board is ON since startup, I should have thought of that. It is now working as expected, I will keep this 4 seconds delay then. The board must go through some initializations at startup I assume.
                  Sure, nothing fancy here though I believe.
                  Thanks a lot for your prompt help
                  ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
                  ; generated by RepRapFirmware Configuration Tool v3.3.0 on Tue Aug 03 2021 20:00:32 GMT-0400 (Eastern Daylight Time)
                  G91                                              ; send absolute coordinates...
                  M550 P"Tests_v0"                                 ; set printer name
                  M552 P169.254.163.66 S1                          ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1                                       ; enable HTTP
                  M586 P1 S0                                       ; disable FTP
                  M586 P2 S0                                       ; disable Telnet
                  M569 P0.0 S0                                     ; physical drive 0.0 goes forwards
                  M569 P0.1 S0                                     ; physical drive 0.1 goes forwards
                  M569 P0.2 S0                                     ; physical drive 0.2 goes forwards
                  M569 P0.3 S0                                     ; physical drive 0.3 goes forwards
                  M569 P0.4 S1                                     ; physical drive 0.4 goes forwards
                  M584 X0.0 Y0.1 Z0.2 U0.3 V0.4                    ; set drive mapping
                  M350 X16 Y16 Z16 U16 V16 I1                      ; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z80.00 U80.00 V80.00           ; set steps per mm
                  M566 X90000.00 Y90000.00 Z90000.00 U90000.00 V90000.00      ; set maximum instantaneous speed changes (mm/min)
                  M203 X60000.00 Y60000.00 Z60000.00 U60000.00 V60000.00 ; set maximum speeds (mm/min)
                  M201 X5000.00 Y5000.00 Z5000.00 U5000.00 V5000.00      ; set accelerations (mm/s^2)
                  M906 X600 Y600 Z600 U600 V600 I30                 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                          ; Set idle timeout
                  M208 X0 Y0 Z0 U0 V0 S1                                 ; set axis minima
                  M208 X999999 Y999999 Z999999 U999999 V999999 S0                  ; set axis maxima
                  ; WARNING: No endstops configured
                  M140 H-1                                         ; disable heated bed (overrides default heater mapping)
                  M564 S0 H0
                  M220 S0
                  ;M669 K0 X1:0:0:0:0 Y0:1:0:0:0 Z0:0:1:0:0 U0:0:0:1:0 V0:0:0:0:1
                  G4 S4
                  M32 duet_test.gcode
                    I don't know if it matters for your application but you may be able to reduce that time with a bit of experimentation.
                    Glad that worked out though. Also I'm not sure why the behaviour would change after the mechanical issue.
