    Error: Short-to-ground on drivers 0 1
    2.3k
    • Ganderundefined
      Gander
      i got a vew Problems with my Duet WIFI
      Hardware:
      Duet WIFI (firmware up to date)
      Meanwell RSP500-24
      Mosfet (only cause the breakout connector couldn´t handle the thick wires)
      Nema 17 17HS4417 1.8° 1.7A
      Nema 17 1.8° 0.5A (for testing)
      I´m trying to build a Core XY.
      I have connected everething like in the wiki.
      for the first tests, i´ve uploaded some existing configs from someone who build the same printer, just to have a basic setting.
      then is tested the Z-axis, they are working, one turing the other direction, but that doesn´t matter so far, cause there is no load on the motors
      after that i tried X and Y axis, more than a realy quick vibrating doesn´t come withe the Error: Short-to-ground on drivers 0 1
      First i thought i connected something wrong, so i checked every wire and found nothing.
      so i startet to asked unkle Google.
      The only thing i found was this discussion about an broken board. There was something about the motor current, so i raised it from 800ma to 1600ma and tried again…
      https://www.duet3d.com/forum/thread.php?id=2425#p22864
      nothing
      because i don´t know what to do, i´ve ripped of all the wires and connected them again in case there was a fault i didn´t notice, maybe…
      but nothing, the same again.
      no i thougt hey what about a broken motor? new one, but shit may happen. so i tried the Z motors on the X and Y axis, the same Error.
      The X and Y motors on Z are working.
      Tried the other nema 17 with 0.5A the same.
      Because of all that, i think there couldn´t be something wrong in the wires and connectors, a broken motor is also impossible it only could be some settings, i don´t know, or i got a broken board.
      So now i don´t know what to do, can annybody help me, or do i have to send the board back?
      Thanks for your Help
      Greetings from Germany
      M122
      Used output buffers: 3 of 32 (13 max)
      RepRapFirmware for Duet WiFi version 1.19 running on Duet WiFi 1.0
      Board ID: 08DDM-9FAM2-LW4SD-6JKFA-3S46N-K3XBW
      Static ram used: 21176
      Dynamic ram used: 95976
      Recycled dynamic ram: 1632
      Stack ram used: 1304 current, 4904 maximum
      Never used ram: 7384
      Last reset 00:25:01 ago, cause: power up
      Last software reset reason: User, spinning module GCodes, available RAM 7416 bytes (slot 3)
      Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      MCU temperature: min 23.8, current 24.9, max 25.3
      Supply voltage: min 23.8, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0
      Driver 0: stalled short-to-ground standstill
      Driver 1: short-to-ground standstill
      Driver 2: stalled standstill
      Driver 3: standstill
      Driver 4: standstill
      Date/time: 2017-09-02 19:46:37
      Slowest main loop (seconds): 0.005705; fastest: 0.000000
      MaxReps: 2, StepErrors: 0, FreeDm: 240, MinFreeDm 235, MaxWait: 489ms, Underruns: 0, 0
      Scheduled moves: 3, completed moves: 3
      Bed compensation in use: none
      Bed heater = 0, chamber heater = -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.19
      WiFi MAC address 5c:cf:7f:ef:6a:b2
      WiFi Vcc 3.12, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 38992
      WiFi IP address 192.168.178.65
      WiFi signal strength -62dBm
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        If you disconnect the X and Y stepper motors and command X and Y movements, do you get the same message, and do the driver chips get hot?
        • Ganderundefined
          Gander
          Good morning,
          with disconected stepper motors i don´t get any mesage
          without the fan i didn´t notice any temperature
          i would say that the chips are a little bit warmer (2-3°)above environmental.
          waited for 5minutes, is this long enough?
            If the drivers don't get hot when you enable them (by commanding movement) with no motors connected, and you don't get the warning messages either, perhaps you really do have either a short between wires or a short to ground in the motor wiring.
            • Ganderundefined
              Gander
              seems legit, but
              why does the z-motors with the z-cable work on the Z connector and doesn´t work on the X and Y connector?
              the X and Y motors either work with their calbles on the Z Connector
              • Ganderundefined
                Gander
                i got other cables her, will crimp a plug on them and test again
                  Is there any sign of damage to the X or Y stepper driver chips, such as a round mark off-centre?
                  • Ganderundefined
                    Gander
                    can´t see any damage.
                    but now it´s getting strange!
                    the new cable, only 15cm long 4 seperate wires so i can see that there is absolutely no connection to each other
                    Motor current is set to 800mA
                    This i tried on the Y-connector
                    trying the small nema 0,5A in my handworking, but doing verry strange movements
                    trying the one of the nema 1.7A (Z-axis), witch are build on the hypercube, the error comes again. That motor worked on the Z-axis connector without problems
                    This on the X-connector
                    now i plugged the Z-motor (giving an error on Y) on the X connector. working for 2seconds doing trange movements and then i had the error.
                    the small 0,5A nema working, but doing that strange movements
                    strange movements:
                    i would say he´s getting an right and left at the same time, so he doesn´t know what to do.
                    i wired everething like on this page
                    https://duet3d.com/wiki/Duet_WiFi_wiring_diagrams
                    first i thought, i have connected 2 wired wrong, so i turned the 2 A wires, the same movement of the motor
                      I think there must be a fault on your Duet, if the motors work OK when connected to the Z connector but not when connected to the X or the Y connector. Please ask your supplier to replace it.
                      • Ganderundefined
                        Gander
                        here a picture of the wires connected to the motor
                        http://www.youscreen.de/metmbwqaj02.jpg
                        • Ganderundefined
                          Gander
                          ok thanks for your help
                          have a great day
