    Is their a macro which get called on job start ?
    • peter247undefined
      peter247
      Hi , I have a set of heater bed cooling fans which in my cura end gcode I've added M106 P2 S1 H0 T30 .
      AND added M106 P2 S0 H-1 at the start of my cura start code, BUT you problem is this get executed after the bed and nozzle has reached temperature , so fans are on until the temperature reached and then switch off .
      Is there a macro which gets called first ?
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      • fcwiltundefined
        fcwilt @peter247
        @peter247
        You can create a file called start.g which is called at the very beginning of a print.
