    Solved does config-override change needs rebooting board?
    Gcode meta commands
    • markduet
      markduet last edited by
      I make changes to my config-override.g sometimes to make adjustments, and then I reboot the board by hitting Emergency Stop after that, to load the new settings. Do I need to Reboot the board or can I just load the config-override.g by "Run"ing it, or is there a better/quicker way with less steps?
      Thanks
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M501_Read_stored_parameters
        markduet 1 Reply Last reply Reply Quote 0
        • markduet
          markduet @Phaedrux last edited by
          @phaedrux Thanks a bunch for the quick reply! That totally solves my problem.
