    x moves with z - crazy
    345
    • duttiundefined
      dutti
      hey
      I had a short ground in driver 3 of my z axis.
      After I fixed this problem, everything is alright, BUT when I move z axis, the x axis is also moving. Is that a normal problem after a short ground?
      I switched the shorted driver to a driver on the expansion board - but same problem.
      When I move x, z axis is not moving..
      Is my Duet broken?
      R.G.
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 16:15:35 GMT+0200 (MitteleuropƤische Sommerzeit)
      G90                                                        ; send absolute coordinates...
      M83                                                        ; ...but relative extruder moves
      M550 P"Duet 3"                                             ; set printer name
      M552 S1 P192.168.2.108                                     ; Wifi
      G4 S4
      M569 P0.0 S1                                               ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                               ; physical drive 0.1 goes forwards
      M569 P0.2 S0                                               ; physical drive 0.2 goes forwards
      M569 P1.2 S0                                               ; physical drive 0.2 goes forwards
      M569 P0.4 S0                                               ; physical drive 0.2 goes forwards
      M569 P0.5 S0                                               ; physical drive 0.2 goes forwards
      M569 P121.0 S1                                             ; physical drive 121.0 goes forwards
      M569 P122.0 S1                                             ; physical drive 122.0 goes forwards
      M569 P123.0 S1                                             ; physical drive 123.0 goes forwards
      M584 M584 X1.1 Y0.0:0.1 Z0.2:1.2:0.4:0.5 E121.0:122.0:123.0    ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16 I1                              ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z640.00 E409.00:409.00:409.00          ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E3000.00:3000.00:3000.00       ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z6000.00 E6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z300.00 E250.00:250.00:250.00         ; set accelerations (mm/s^2)
      M906 X1300 Y1300 Z2500 E1000:1000:1000 I30                 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                    ; Set idle timeout
      M208 X-10 Y-10 Z10 S1                                      ; set axis minima
      M208 X1030 Y1030 Z1030 S0                                  ; set axis maxima
      M574 X2 S1 P"^io3.in"                                      ; configure active-high endstop for high end on X via pin ^io3.in
      M574 Y2 S1 P"^io1.in"                                      ; configure active-high endstop for high end on Y via pin ^io1.in
      M574 Z1 S1 P"^io2.in"                                      ; configure active-high endstop for low end on Z via pin ^io2.in
      M558 P0 H-5 F300 T300                                       ; disable Z probe but set dive height, probe speed and travel speed
      M556 S50 X0 Y0 Z70                                         ; set orthogonal axis compensation parameters
      M557 X10:10 Y10:10 S20                                     ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138               ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                         ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 R0.243 C586.2 D33.87 S1.00 V0                   ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                    ; map heated bed to heater 0
      M143 H0 S120                                               ; set temperature limit for heater 0 to 120C
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4138           ; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"out1" T1                                         ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S250                                               ; set temperature limit for heater 1 to 250C
      M308 S2 P"122.temp0" Y"pt1000" R2200                       ; configure sensor 2 as PT1000 on pin 122.temp0
      M950 H2 C"122.out0" T2                                     ; create nozzle heater output on 122.out0 and map it to sensor 2
      M307 H2 B0 S1.00                                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S250                                               ; set temperature limit for heater 2 to 250C
      M308 S3 P"123.temp0" Y"pt1000" R2200                       ; configure sensor 3 as PT1000 on pin 123.temp0
      M950 H3 C"123.out0" T3                                     ; create nozzle heater output on 123.out0 and map it to sensor 3
      M307 H3 B0 S1.00                                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H3 S250                                               ; set temperature limit for heater 3 to 250C
      M950 F0 C"121.out1" Q500                                   ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 S0 H-1                                             ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"121.out2" Q500                                   ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 S1 H1 T45                                          ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"122.out1" Q500                                   ; create fan 2 on pin 122.out1 and set its frequency
      M106 P2 S1 H-1                                             ; set fan 2 value. Thermostatic control is turned off
      M950 F3 C"122.out2" Q500                                   ; create fan 3 on pin 122.out2 and set its frequency
      M106 P3 S1 H2 T45                                          ; set fan 3 value. Thermostatic control is turned on
      M950 F4 C"123.out1" Q500                                   ; create fan 4 on pin 123.out1 and set its frequency
      M106 P4 S1 H-1                                             ; set fan 4 value. Thermostatic control is turned off
      M950 F5 C"123.out2" Q500                                   ; create fan 5 on pin 123.out2 and set its frequency
      M106 P5 S1 H3 T45                                          ; set fan 5 value. Thermostatic control is turned on
      M950 F6 C"out4" Q500                                       ; create fan 6 on pin out4 and set its frequency
      M106 P6 S1 H-1                                             ; set fan 6 value. Thermostatic control is turned off
      M950 F7 C"out5" Q500                                       ; create fan 7 on pin out5 and set its frequency
      M106 P7 S1 H T45                                           ; set fan 7 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                           ; define tool 0
      G10 P0 X30 Y28.25 Z45                                      ; set tool 0 axis offsets
      G10 P0 R0 S0                                               ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 F2                                           ; define tool 1
      G10 P1 X0 Y0 Z0                                            ; set tool 1 axis offsets
      G10 P1 R0 S0                                               ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 D2 H3 F4                                           ; define tool 2
      G10 P2 X0 Y0 Z0                                            ; set tool 2 axis offsets
      G10 P2 R0 S0                                               ; set initial tool 2 active and standby temperatures to 0C
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"         ; set voltage thresholds and actions to run on power loss
      duttiundefined 1 Reply Last reply Reply Quote 0
      • duttiundefined
        dutti @dutti
        @barbarossa-cologne
        Switching drivers -- same problem šŸ˜•
        kb58undefined 1 Reply Last reply Reply Quote 0
        • kb58undefined
          kb58 @dutti
          @barbarossa-cologne
          Two M584 commands on the same line. Not saying that's it, but who know what it's doing.
          Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
          • kb58undefined
            kb58 @kb58
            @kb58 The code listing suggests that it was generated by the configuration app. I've read several threads where someone's used the results and it didn't work as expected. I suggest going through that code line by line, using the Gcode Directory, https://duet3d.dozuki.com/Wiki/Gcode#main and double checking all the M commands and whether their parameters make sense on your setup.
            • duttiundefined
              dutti @kb58
              @kb58
              Before I had the short ground, everything was fine. I try with changing the m584...
              Would be to easy
              Same problem with one m584 command..
              Thank you
              • duttiundefined
                dutti @dutti
                It's crazy because the x driver is in a different board. And it doesn't care on which driver.
                Y is working completely fine (and not moving when z moves).
                  dc42 administrators @dutti
                  @barbarossa-cologne this behaviour is caused by the M556 command in your config.g file.
                  • duttiundefined
                    dutti @dc42
                    @dc42 do you mean in row 44?
                    What is wrong there / just delete them ?
                    It's curios because this behaviour first shows up after short ground..
                    Hopefully it's the reason
                      @barbarossa-cologne the M556 line says that you have axis skew and that you want to compensate for it, by moving X too when Z changes. It's unusual to use skew compensation, and in any case the amount of compensation specified in your M566 command is much too large to be reasonable. I suggest you delete that line.
                      • duttiundefined
                        dutti @dc42
                        @dc42 ok thanks for this information. It's made by the config tool and I'm not a professional, yet. Sry
                        Nice to have such a good support
                          Phaedrux Moderator @dutti
                          @barbarossa-cologne said in x moves with z - crazy:
                          You would have had to check the box to enable it in the tool
                          "Enable Orthogonal Axis Compensation"
