    Maestro external driver not working as expected
    • Scarface_the_foxundefined
      Scarface_the_fox
      Hello
      I started using an external driver to drive an axis on my 3d printer and have been having nothing but problems with getting this to work.
      The issue I am having is that the duet3d maestro does not seem to respond to the M569 Gcode properly in particular is the polarity, Which does not seem to make any change electrically with the wiring and does not seem to make sense either
      I have attached my config.G file below the line in particular that has the problem is this one
      M569 P5 S1 R1 T2 ; physical drive 5 goes forwards
      I have tried it with both R1 and R0
      The problem I am having is when measuring with a multimeter on the enable, step I am getting the same voltages on both as well.
      When Idle / Motor OFF
      Step = 0v
      Enable = 5v
      When motor running
      Step = 5V
      Enable = 0V
      Which does not make sense as with R1 Step and enable should be active high and R0 both should be active Low
      Any help reguarding this would be greatly appreciated.
      *Edit : I forgot to mention that the external driver I am using is an DM420A which requires active High signals and also to convert from the 3.3v signals I am using a logic level converter that I have used on multiple projects in the past that works really well to convert the 3.3v into the 5v requirement.
      ; Configuration file for Duet Maestro (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.3.0 on Thu Aug 12 2021 16:34:59 GMT+1000 (Australian Eastern Standard Time)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"My Printer"                             ; set printer name
      M552 P0.0.0.0 S1                               ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P1 S0                                     ; physical drive 1 goes backwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S0                                     ; physical drive 3 goes backwards
      M584 X5 Y1 Z2 E3                               ; set drive mapping
      M350 X32 Y32 Z32 E64 I0                        ; configure microstepping without interpolation
      M92 X76.74 Y151.47 Z5156.55 E2202.90           ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X10 Y10 Z0 S1                             ; set axis minima
      M208 X200 Y200 Z200 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M950 S0 C"^zprobe.mod"                         ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X19 Y0 Z2.5                           ; set Z probe trigger value, offset and trigger height
      M557 X25:200 Y25:195 S20                       ; define mesh grid
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      • o_lampeundefined
        o_lampe @Scarface_the_fox
        @scarface_the_fox said in Maestro external driver not working as expected:
        The DM420 is not a closed loop driver, so you have to specify the 'T' parameter in more detail. (eg. T2.5:2.5:5:5)
          Scarface_the_fox
          Thanks for the reply,
          I have tried changing the T value and it did not help in the slightest as the enable was still low when movement was required.
          I have a dodgy fix that I tried after sending the message in the first place which is feeding +5v into the enable pin on the DM420. So that the DM420 is always enabled.
          This is far from ideal and would still prefer some way of having the duet3d control the enabling of the stepper driver.
            dc42 administrators @Scarface_the_fox
            @scarface_the_fox I have never tested support for external drivers on the Duet Maestro. On the basis that untested features are usually buggy, it may well be the case that external drivers are not fully supported.
