Weird behaviour after first print
Are there example configs from other voron users that use this probe?
Have you tested in standalone mode as a control?
There are many many other users and I took over the config from them. And it already worked for multiple weeks.
Nope, not tested standalone. But as said I just did acomplete fresh SBC install.
Well I'd say either test your current config files in standalone mode to eliminate the SBC for testing, or wait for chrishamms updated build.
Right now we're mixing 3 confounding factors, unproven macros, SBC mode, and beta firmware. When in doubt, try and roll it back to the most basic configuration and when it's working, start adding new things one at a time. -
@martinnyhc try
; bed.g ; called to perform automatic bed compensation via G32 if !move.axes[0].homed && !move.axes[1].homed && !move.axes[2].homed G28 ; home M558 K0 H10 F400 ; set trigger height M561 ; clear any bed transform M98 P"0:/macros/sys/undock_klicky_probe.g" ; undock clicky probe G30 P0 X20 Y25 Z-99999 F9000 ; probe Z left front G30 P1 X20 Y320 Z-99999 F9000 ; probe Z left rear G30 P2 X330 Y320 Z-99999 F9000 ; probe Z right rear G30 P3 X330 Y25 Z-99999 S4 F9000 ; probe Z right front G1 H2 Z12 F2600 ; raise head M400 ; finish move, clear buffer M558 K0 H2.5 F200 ; trigger height to 2.5mm after first run while move.calibration.initial.deviation >= 0.003 ; Perform additional leveling if previous deviation was over 0.03mm. if iterations = 5 abort "Too many auto tramming attempts" G30 P0 X20 Y25 Z-99999 F9000 ; probe Z left front G30 P1 X20 Y320 Z-99999 F9000 ; probe Z left rear G30 P2 X330 Y320 Z-99999 F9000 ; probe Z right rear G30 P3 X330 Y25 Z-99999 S4 F9000 ; probe Z right front G1 H2 Z12 F2600 ; raise head M400 ; finish move, clear buffer echo "BTC: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm" continue G1 Z12 ; Raise nozzle M98 P"0:/macros/sys/dock_klicky_probe.g" ; dock clicky probe G28
Did you solve your problem? I'm struggling with QGL and mesh with the klicky probe... My problem is, that I use the autoz calculation macro at first and then I try to perform a QGL... After the homing and autoZ macro, the Z0 is at the surface of the bed plate - as expected. But then my QGL fails...
@medicusdkfz For me it was a loose connection on the klicky probe which only occured randomly.
@martinnyhc Please would you share your RRF3-configuration with me? You'll find my mail adress in my profile...
Thank you in advance...
How is your process for creating a mesh from scratch? Do you also use a seperate z-microswitch for calculate the difference between the nozzle and the switch point of the klicky probe?
You have to call the probe deploy from within your homez and then again in your beg.g or other macros that need the probe. Conditonal gcode makes this an easy check and remedy.
The error is because the NC probe state is 1000 when the probe is not connected or triggered. you have to include in your macros the logic to address these states.
You should go look a the macros for Euclid Probe. We've been running this reliably for over 2 years at this point, both with fixed dock and moving bed pickups.
Also, we have found that inspecting the actual probe value is more reliable that checking the probe token in the object model. In the case of a mis-deploy, which is really rare with Euclid Probe, the probe value is more telling.
