BLTouch Won't deploy
@eegroeg I can confirm BLTouch is now Probing with M280 P0 S10/M280 P0 S90
@eegroeg said in BLTouch Won't deploy:
M558 P9 H4 F120 T6000
Your command isn't correct. You're missing the pin name. You need:
M558 P9 C"^io7.in" H4 F120 T6000
Change that and send M98 P"config.g" again.
@Phaedrux I also am struggling to update it, when I upload the ZIP then run the M115 command after reboot I get...
M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-02-11
Where are you uploading it to? Should be the system tab.
@phaedrux That's great now M401 and M402 work! Thank you
@phaedrux Yeah I am in system tab and hit "upload system files then select the zip files which uploads them but when rebooting and running M115 no change.
Are you uploading the zip file as is? Don't extract it first.
@phaedrux Yeah I upload the zip as it is from my downloads and it uploads a load of items then restarts and M115 gives me the same output that it is still on M115
Try sending m997 in the console
@phaedrux said in BLTouch Won't deploy:
m997
That's done it. Thank you for all your help BLTouch is working now and printer is updated
Can you post the results of M122?
Can you check the version of DWC as well? -
M122
Sorry for the delay please see my M122 results below. I am on DWC version 3.3.0M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-9P63L-DJMSS-6J9FD-3S86R-TBD39 Used output buffers: 3 of 40 (13 max) === RTOS === Static ram: 150904 Dynamic ram: 91676 of which 0 recycled Never used RAM 111612, free system stack 206 words Tasks: NETWORK(ready,30.3%,212) ETHERNET(notifyWait,0.2%,117) HEAT(notifyWait,0.0%,331) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.5%,93) MAIN(running,61.5%,1092) IDLE(ready,0.4%,29), total 100.0% Owned mutexes: === Platform === Last reset 00:00:28 ago, cause: power up Last software reset at 2021-08-31 21:43, reason: User, GCodes spinning, available RAM 108404, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Step timer max interval 140 MCU temperature: min 19.1, current 27.7, max 27.9 Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0 Driver 1: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0 Driver 2: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0 Driver 3: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0 Driver 4: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 25307, writes 11 timeouts 0, SG min/max 0/0 Date/time: 2021-08-31 21:48:07 Slowest loop: 7.54ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.1ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 254, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 142/0/0 Tx timeouts 0,0,141,0,0,111 last cancelled message type 30 dest 127 === Network === Slowest loop: 15.23ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 2 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 0
