High temperatures where the printer is
I live in Valencia, these days it is very hot, a humid heat.
In the DWC you can read that the temperature, when idle (Printer on NOT printing) is 45º CelsiusIs this temperature admissible? or should I avoid using it?
From what temperature should you stop?
Is there a command to stop the printer if a certain temperature is exceeded automatically? -
When temperature are you reading as 45c? The MCU temp? The ambient temp?
As long as the board has some active fan cooling during a print you're fine.
