    Trouble Declaring Global Var
    Gcode meta commands
    declare global help
    • printernoodleundefined
      printernoodle
      How do you define a global variable?
      I have tried entering
      global status=true
      in the console
      And then the web interface just goes into a non stop connect disconnect loop.
      Tried the same with
      global status=1
      even tried putting this declaration right into gonfig.g
      That just put the entire system into the same connection connect disconnect loop regardless of reboot.
      I've been struggling with this for a bit now....
      cant get a global variable created...
      What am I not doing here?
      • fcwiltundefined
        fcwilt @printernoodle
        @printernoodle
        What firmware version are you using?
        What board are you using?
          printernoodle
          @fcwilt
          sorry it's 3.3 rc2
          duet 2 wifi
          • fcwiltundefined
            @printernoodle
            Well the release version of 3.3 is out and it works fine with global variables.
            I suggest you update and try then.
            Have you tried any other variable names?
            printernoodleundefined 3 Replies Last reply Reply Quote 1
              printernoodle @fcwilt
              @fcwilt
              yes I've tried "global derack" "global magprobe_status" "global qgl"
              all start some weird connection loop on the DWC
                @fcwilt
                and then
                Over and over again.....frozen on boot up
                I will try the new release.
                  @fcwilt
                  going to the release version of 3.3 seems to have fixed it.
                  Thank you very much indeed!!
