    Question about semi automatic thermistor calibration
    • peirofundefined
      peirof
      I have read this method for semi automatic thermistor calibration.
      autimatic thermistor calibration
      This method sounds great, I haved a lot of issues for thermistor setup...
      I have some questions:
      • when guide said un point 4,of semi automatic method that place a jumper,can be undertanded as a wire? I suppose that this not produce a short to ground...
      • all process, must be done with duet powered on?
      Thx
      kb58undefined 1 Reply Last reply Reply Quote 0
      • kb58undefined
        kb58 @peirof
        @peirof If you're asking "can you use a wire instead of a jumper", yes, both are the same thing. Just add it across where the thermister connects, and don't worry about shorting to ground.
        Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
        peirofundefined 1 Reply Last reply Reply Quote 0
        • peirofundefined
          peirof @kb58
          @kb58
          thx... and all process, must be done, with board powered on?
            dc42 administrators @peirof
            @peirof said in Question about semi automatic thermistor calibration:
            @kb58
            You can power the board off when fitting and removing the link. The M308 H# H999 and M308 H# L999 perform separate calibration operations.
            • peirofundefined
              peirof @dc42
              @dc42 i can do semi automatic calibration with Duet 2, not supported
                No, because Duet 2 does not measure the Vref and Vssa voltages.
