    Weird behavior of the printer
    • DR8undefined
      DR8
      Hi guys,
      I have a H-bot system with Duet Wifi. The weird problem is that everytime after I print a calibration cube 20x20x20 (i have designed in solidworks 2014) the printer head goes down into the print and I have to press emergency stop. I print different other objects and never did this. I tried cura and slic3r and in both cases behaves the same. Here's my start/end gcode from slic3r:
      start:
      G21 ; set units to millimeters
      G90 ; use absolute positioning
      M83 ; relative extrusion mode
      G28 ; home all axes
      G32 ; ABL
      G92 E0.0 ; reset extruder distance position
      M117 ;printing
      end:
      M104 S0 ; turn off extruder
      M140 S0 ; turn off heatbed
      M107 ; turn off fan
      G1 Z5 F3600
      G1 X0 Y0;
      M84 ; disable motors
      What's the problem?
      • tomasfundefined
        tomasf
        I guess the [c]G1 Z5 F3600[/c] line is the problem. In absolute mode, it moves Z to 5 mm. Use [c] G91[/c] to enable relative positioning mode first, and it should work better.
        • DR8undefined
          DR8
          So should it be:
          G91
          G1 Z5 F3600
          I think I'm gonna make like this:
          G91 ; use relative positioning
          G28 ; home all
          G32 ; ABL
          M117 ;printing
          M107 ; turn off fan
          G1 Z5 F3600
          G1 X0 Y0;
            No, the G91 needs to be in the end gcode, because it's just the G1 Z5 that you want to use relative axis coordinates for, not the whole print.
            If you disable motors at the end of the print, you will need to home the printer again before starting the next print. The alternative is to leave them enabled. The current will be reduced to the idle value (default 30% of normal) after 30 seconds.
            • DR8undefined
              DR8
              Oh, i got it. Off course this is how it should be…. sometimes I'm so....... Thanks alot!
