    Duet wifi access point setup
    • mp105undefined
      mp105
      Re: Duet WiFi Access Point setup problems
      Hi there I have a duet2 with the latest firmware. The printer is out of range for our wifi so need to set it up as an access point. However, when I power on the printer it won’t automatically start the access point I have to plug in my laptop and run M552 S2 through yay to fire up access point . Once started it is fine. Not sure how to fix.
      • chrishammundefined
        chrishamm administrators @mp105
        @mp105 Have you tried to replace M552 S1 with M552 S2 in your config.g? If there is no such code in your config file, try to add that.
        Duet software engineer
