    Connecting a Relay Controlled Vacuum Pump
    • JRCLundefined
      JRCL
      While I'm not new to 3D Printing, I am to using microcontrollers and embedded software. I was planning on getting the Duet 2 Wifi and Duex 5 to control 7 steppers, 2 heaters, and 2 thermistors. However, I also have an OTS vacuum pump I want to control via a relay. If I attach the Duex 5 to the Duet 2 Wifi what pins would be the best use on the Duet to control a relay for the pump? If even possible?
      Cheers,
      JRCL
        What will the pump be used for? You can use pretty much any pin you want to control a relay, but the most obvious would be a fan or heater.
        https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names
        • o_lampeundefined
          o_lampe @JRCL
          @jrcl
          what Phaedrux said is probably best. I'd check the schematics for an output with 'flyback diode' or add a flyback diode across the coil pins (with reversed orientation).
          Reason is, the coils magnet field can create high voltages when switched off. (think: ignition coil and sparkplug)
          Maybe the relais you've picked already has a flyback diode incorporated?
