M906 for external drivers
Hey guys, I'm setting up a Duet2 wifi for a CNC router and I'm using external drivers so I'm wondering if I just omit the M906 command or do I need to set anything for that as there aren't any drivers to actually set the current for.
Thanks.
External drivers should have a way to set the current.
You cannot do it with M906.
Right, so then just omit the M906 from the config.g correct?
@baird1fa said in M906 for external drivers:
Yes.
If you're not suing the internal drivers at all you can disable them entirely with
M569 P# R-1
where # is the driver number.
