    Send a console message at a given event
    710
    • A Former User?
      A Former User @jay_s_uk
      @jay_s_uk said in Send a console message at a given event:
      @the_dragonlord you could use M117 to display a message and then something in daemon.g to send that message.
      then setup a variable in config.g e.g.
      global printing = false
      in start.g use
      set global.printing = true
      then in daemon.g
      if {global.printing == true && state.status == "idle" && heat.heaters[1].current < 50}
         M117 "display message"
         set global.printing = false
      That will only run if all 3 of those conditions are met. Including the printer status means if won't send that message if its in the fault state and also won't send a message if you use more than one tool.
      excellent I'll try it right now!
      • A Former User?
        A Former User @A Former User
        @the_dragonlord said in Send a console message at a given event:
        in start.g use
        then in daemon.g
        I don't find neither start.g or daemon.g files...where are they located?
        • fcwiltundefined
          fcwilt @A Former User
          in start.g use
          then in daemon.g
          Create them yourself in the sys folder - the folder where config.g is located.
          A Former User? 2 Replies Last reply Reply Quote 0
          • A Former User?
            A Former User @fcwilt
            @fcwilt said in Send a console message at a given event:
            in start.g use
            then in daemon.g
            excellent, thanks
            • A Former User?
              in start.g use
              then in daemon.g
              The index for the 2 tools to use in the heat.heaters array are 0 and 1 or 1 and 2?
                jay_s_uk @A Former User
                @the_dragonlord heaters for tools would be 1 and 2. Activate the object model browser as it'll help you see where everything is stored
                • A Former User?
                  uhm....I apologize for my ignorance....what's the object model browser?
                  EDIT
                  it's a plugin, I've found it
                  jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 1
                    @the_dragonlord it's a plugin. It can be activated in settings - general - plugins
                    • fcwiltundefined
                      Go to the Settings - General section in the DWC.
                      Select the tab BUILT-IN PLUGINS.
                      Locate the Object Model Browser and start it.
                      A Former User? 1 Reply Last reply Reply Quote 1
                      • A Former User?
                        unfortunately the telegram bot doesn't "intercept" the messages as I workngly said before but "only" the console messages....is there a GCODE to start a row in the console?
                        EDIT
                        GOT IT M118 L2
