    JAWS N 3D
    My Duet controlled machine
    4z steppers custom fire sentinel large large format overkill
    568
    • JawsN3Dundefined
      JawsN3D
      Finally have 98% of this thing sorted out. I've done my damnedest to make sure I haven't had to ask any stupid questions......
      ..... like how the hell I ended up with bed one and bed two with the hot end thermistor tied to bed number two.....weird.
      Most of what I've dealt with are errors with converting my stuff to 3.0 + from 2.03.
      Anyways figure you all might want to see our "bigger boat"
      We are using it to make parts for our Oldsmobile.
      Duet2/duex5, now with 3.3 on it and the paneldue....n some other stuffs.
      I drew out and waterjet it...and a bunch of more minimalist brackets etc that it has 2 smaller brothers.
      This is a little older video but it gives you a good view of all the important stuff.
      https://youtu.be/Ua9t-zh2tIw
      https://www.thechicagogarage.com/attachments/20210822_123258-jpg.97905/
      Self designed/waterjet/built enclosed 800x360x725 Cartesian machine.
      Duet2/duex5, Moons, Hemera
      Rpi4 as Fire Sentinel with 110v contactors.
      Everything but the kitchen sink....
      ...much like our Twin engine Oldsmobile...
      fcwiltundefined 1 Reply Last reply Reply Quote 3
      • fcwiltundefined
        fcwilt @JawsN3D
        @jawsn3d
        Why is the Z axis movement making so much noise?!?
        JawsN3Dundefined 1 Reply Last reply Reply Quote 0
        • JawsN3Dundefined
          JawsN3D @fcwilt
          @fcwilt 40:1 planetaries on the 4 z steppers to prevent power off drift
          Regards, James
          • fcwiltundefined
            fcwilt @JawsN3D
            @jawsn3d said in JAWS N 3D:
            Regards, James
            40:1? wow.
            Here is a video of my first (and currently only) printer using belt drive for Z.
            The planetary gearboxes are only 5:1 but that is enough to hold the bed in place.
            3Z Leveling Video
            • JawsN3Dundefined
              JawsN3D @fcwilt
              @fcwilt our cold bed is 1/2inch 6061 plate with the hotbed above it being 1/4inch plate....pretty heavy bugger.
              Mesh is slow but it shouldn't need to be probed often
              fcwiltundefined 2 Replies Last reply Reply Quote 1
              • fcwiltundefined
                fcwilt @JawsN3D
                @jawsn3d
                Indeed it was clearly heavy but that noise would drive me bonkers.
                JawsN3Dundefined 1 Reply Last reply Reply Quote 1
                • fcwiltundefined
                  fcwilt @JawsN3D
                  @jawsn3d
                  I forgot to ask - what is the lead screw lead?
                  • JawsN3Dundefined
                    JawsN3D @fcwilt
                    @fcwilt 8mm/rev 1000mm
                    That was actually filmed with the old hundred to one gear boxes which was us ordering without looking at the selected option box....doh'
                    What drove us insane was trying to get the ft6 to work.... with a bad board and bad bearings and other various defects. It's what led me to design my own.... I'm pretty sure it's a fairly common story among us lunatics
                    • fcwiltundefined
                      fcwilt @JawsN3D
                      Just FYI if you use lead screws with 2mm lead you might not need such high ratio geared steppers.
                      Before I switched to belts I used lead screws and found that 2mm lead was good at holding position when power was off.
